Question about LG WM-2277HW Front Load Washer
My whrlpool frnt load washer is using hot water in evry setting
My frontload washer has stopped using clod water,i disconnected hoses and cleaned filters, cold water does come from hose when disconnected but clothes are very hot and have obviously been rinsed in hot when removed. all rinses are supposed to be in cold on this model(whirlpool duet sport)
  • Collins Debra Sep 23, 2017
    I am guessing somehow the water hoses are hooked up backwards to the machine. Try reversing them.
    Problem Solver:
  • 8 Answers
Did you check to see if the hot and cold are hooked up backwards? Try switching them.
Posted on May 01, 2009
6ya staff
SOURCE:
Washer flashes F8 E1. What is this
hook up hot hose and turn on the hot water and dont use hot water control it will not use no hot water ,but washer need to see the water pressure ,but will not use no hot unless you ask for it Sonny
May 29, 2014 | Whirlpool Duet GHW9150P Front Load Washer
My prblem is water is coming out frm frnt panel n a huge cracking sound after 2 hrs. frm my 1 yr old ac whrlpool crome.plz suggest me
Check that the unit has a good tilt back so the water will drain out of the back of the unit. Unplug the unit and use a hose to spray out the back of the unit and clean it out good.
Mar 24, 2013 | Refrigerators
Hot water use on a cold /cold cycle
I bleive hot water in introducted @ begaining of cyle to disolve deterant call whirlpool 800 number .
Oct 26, 2009 | Kenmore 43142 Front Load Washer
Wash starts, then stops postin E10 and now soap does not dispense
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Aug 02, 2009 | Frigidaire GLTF2940F Front Load Washer
Mold and smell from Maytag washer
The mold will be growing in the upper parts of the agitator basket above the water line. Spray these areas with a bleach/water mixture using a spray bottle. Turn off the hot water valve to your washer. Disconnect the hose connected to this valve. Connect a leak free garden hose to the valve. Connect a garden sprayer to the other end of the garden hose. Turn the hot water valve back on. Check for leaks. Use the garden sprayer to rinse and remove the mold. Be careful to keep all of the water in the agitator basket. Turn off the hot water valve. Reconnect the hose from the washer to this valve. Turn the hot water valve back on. Check for leaks. Run a wash cycle with an empty load.
Jan 15, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Leaking washer
Replace the valve, or if new, have them do it. You are sure it is the valve and not where the hot warter hose attaches? Confirm by hooking up hot water under preasure to see if that seals itself.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Hot water doesn't work
Disconnect the hot water hose from the washer, put the hose over in the washer and run some water to make sure you don't have a plumbing problem. Look inside the valve where the water connects to the washer, there should be a screen that may need cleaning.
If everything looks and works good to this point then you will need a meter to see if power is getting to the water valve and to check the hot water solenoid on the water valve. No power to the water valve, then replace the water select switch. Bad solenoid, then replace the water valve.
Jan 01, 2009 | Fisher and Paykel GWL11 Top Load Washer
Lg frontload wash
I removed the top panel of washer(4 screws and slide). Then found the small 1/4" hose that goes from drum to drain hose to be pluged with goo. I cleaned inside of hose and washer worked fine.
Dec 30, 2008 | LG WM-2277HW Front Load Washer
Washer doesnt take hot water
All the symptoms described are typical of a water inlet valve that has either become clogged with sediment or has a solenoid failure. You can elect to replace the water inlet valve, or attempt to clean. Cleaning requires shutting off the water source and disconnecting the inlet hoses. Check the sediment screens in the water inlet valve and clean with cotton swabs and distilled vinger. Place the hoses in the wash tub and turn on the water supply to make sure the hoses are clog free. Sometimes a good cleaning can help. However, the majority of the cases involve replacing the valve. The following link explains how:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
I hope this information is helpful. Anyone with questions are encouraged to post back and let me know.
Aug 01, 2008 | Kenmore 24032\24036 Top Load Washer
LG WM-2277HW Front Load Washer Logo
225 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
