I have a Haier HLP21N that had the same problem. Three blinking lights and refused to spin. It turns out the issue was the lid. The left side plastic hinge had broken the week before. What I didn't realize is that when the lid closes, that back hinge pushes up a rod which tells the machine that the lid is closed and it's safe to spin. So check that hinge and if it is broken you will either need to order a new lid or find some material to stuff under the hinge so that it stays up. I chose the latter option. Just know that going the DIY route means that your machine will continue to spin if you open the lid going forward!
David you just helped me. Thank you!It happened this morning - tub of water/clothes - and took off lid and found the broken hinge. Did as you suggested, it is functioning. Thank you for sharing. :)
I have the same issue with the lights. Water goes in, stops then lights come on, all 3 flashing. The cycle wont finish. The hinge seems fine though.
No spin with alarm means the unit is out of balance.
The troubleshooting manual reads:
"The safety switch acts. The
spinning cannot work (The
WASH, RINSE and SPIN
indicator flash and alarm goes
off every 10 seconds). If
trouble cannot be solved after
alarming, it will alarm again
every few minutes."
To solve this the load must be balanced:
Make sure to level the machine on a solid floor. Also you may have to redistribute the clothing in the tub for even weight distribution.
SOURCE: Haier Top Load Washer doesn't spin
Hi
There can be two possibilities,one if it has a belt, it is either stretched or slipping or if it doesnt have a belt then there is a clutch like device between the motor and the basket, which is either broke or cracked.
Or follow this easy steps...
Unplug the washer and turn off the water faucets.
Disconnect the water hoses and the drain hose and pull the washer away from the wall, leaving yourself enough room to work behind the appliance.
Lay an old towel down to kneel on and soak up any water that leaks from the hoses.
Remove the rear access panel.
Locate the motor. The rubber drive belt goes around a pulley wheel attached to the motor.
Press on the belt. If it gives more than ¾ inch or so, it needs to be tightened.
Loosen the mounting nut for the motor and push the entire motor to increase the tension on the belt.
Hold the motor in place and tighten the mounting nut.
Make sure you don't tighten the belt too much or it will break. You should be able to press on it and feel it give just slightly.
Replace the drive belt if it shows signs of wear.
Thanks for contacting fixya.com
Testimonial: "Thanks! I guess you're right. The belt seems to be too loose and shows signs of wearing. Already ordered new one. Thanks again!"
