after looking at reviews written on
http://www.chainsawsdirect.com/Earthwise-CVPS41008-Chain-Saw/p7224.html
Robert
Tried chain saw. Working on limbs about 12 ft above ground.
First limb about 3 inches diameter, Oak. Worked fine.
Second limb same size. Cutter slip off branch could not stop the saw from hitting ground. Broke case where it attaches to pole.
No parts, and no way to repair it as company had no idea what kind of cement/glue I could use. So one branch cost me $120.00.
Sent To Customer Service
Shawn
Like Robert my saw hit the ground and busted in the same spot (this will happen to you sooner or later) and you can not get repair parts, its now a door stop.
Pros: Easy To Use, Light Weight
Cons: Can Not Get Repair Parts
I am guessing you mean the entire cutting end of the saw too, I would get a new one either same model so you have a spare pole or find a another brand that definatly sells spare parts.
Ive never used a electric polesaw but have done alot of work with with longer petrol and shorter hydrolic polesaws, even top of the range they can be broken easily always keep the chain sharp, cut one branch at a time or small clumps on a hedge.
Commonly they get dropped cause they get really heavy extended a shoulder belt helps alot as do coffee breaks.
Or they get jammed in the branch being cut which can be really dangerous with a half cut branch, be ready to run.
Also never use from a ladder
