The fabric seal in the front of the drum of my 3 1/2 yr old Maytag Neptune dryer is falling out. The repairman Maytag sent out says the simple part is only available by buying $350 drum assembly. Over $500 to repair with labor. Can another seal be used? Is this something we could do ourselves?
Give this site a try. Some guy on the forum had the Neptune issue and found a replacement seal. There are some how-to videos on YouTube(may not be your specific dryer, but same idea.) I'll let you have the joy of looking on YT.
Maytag Neptune Dryer MDE9700AYW Felt Drum Liner
SOURCE: Fabric softener dispenser
remove top of machine, there is a arm running across from programe dail, to drawer despenser,its spring loaded it determines which compartment the water gos into,check it
SOURCE: NEPTUNE WASHER
"downy ball" is designed to open at the end of first spin that is the way to go without stopping machine. works very well and costs just a few dollars
SOURCE: Maytag Neptune FAV6800AW - Fabric Softener dispenser doesn't empty
I had a similar problem with the fab. softener chamber. Clean
out the buildup and it will drain. To do this, remove the cap and wipe out the softener. Also, be sure to wipe inside the drum, just below the dispenser.
As for a water flow to the dispenser- You will need to remove the plastic portion of the lid. Start with the detergent dispenser, then gently remove the bottom corners of the lid. Then are held by two plastic clasps. Then gently remove the "L" shaped plastic holders. Use a pipe cleaner to clean out the tube where the water flows directly out of the unit, before entering the lid. I did this last night, and it works beautifully!
SOURCE: Neptune super stack sl-2
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Sounds like service time!!!!!!!!!!!!!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
They told me the same thing. I just can't believe that the whole drum needs to be replaced. Surely just the felt gasket can be purchased?!
