SOURCE: oe message on lg front loader washer model
It is a long drain error and occurs when the washer is not fully drained after 10
minutes of draining. Remove the cabinet cover and check the following:
Main board replacement:
Check
pump coil resistance between the terminals using an ohmmeter.
Resistance should be between 10-20 ohms. If the resistance is too high
or too low, replace the drain pump.
SOURCE: Lg front loader model wm2277hw..Water not
WM2277 technical service Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
