First, check if this warning is a SERVICE SOON or a CHECK ENGINE light. First just is a reminder that you need check or change fluids, filters and periodical maintenance. Check engine light measn that some fault code is detected and some sensor is sending this signal to the coputer car, you will need scanned the computer car with OBD scanner reader tool in order to know exactly what is the fault code number stored there.
It seems your machine may be a bit older than 7 years; it appears on an Intravia service CD covering 2001-2003. These are generally not available concurrent with the production period.
I am now retired but the Intravia paper manuals were excellent and returned their cost many times over.
The $142 is probably a fair price for a service call by today's standards but if you are interested in maintaining your own machine, I can recommend this to you:
Intravia 2001-2003 Service CD
Note: This will provide information on any service your machine might need unless an outright failure of a board should occur; they do not contain detailed schematics required for such trouble-shooting.
Good luck-
ensure that you have the reciver connected to a display monitor e.g t.v. set, there you'l be able to make all the necessary ammendments.use the video out or use the HDMI out to connect to your t.v.
which speakers are using for the avr 142?
The NAXA NX-142 came with a miniature CD you must use the CD to install the software called AMV converter to your computer. Then run the AMV converter with the NX-142 plugged into the USB port. You can then convert certain videos like WMV files into AMV files which can be automatically uploaded to the NX-142 be sure to choose to upload the videos into the MOVIED subdirectory to help keep things organized on the NX-142 The AMV converter will allow certain settings to be selected. The manual is helpful but the printing is so small that I can't read it even with glasses. Good Luck
The general install procedure for USB devices is to install the drivers/software first then connect the device. The PC should then detect and initialize the device.
I however recommend you check and follow manufacture's guidance/steps.
