The Pg series cannot play movies from Usb they have no processor for that
The first to have this were the Pq and then you could do this kind of hack
Sorry
Try with ok and ok from the tv set and remocon
or also try menu and menu
but to inform you this works with specific suffix for your tv
hope that was helpful
I think this calls for a phone call to LG customer service to see what can be done and to inquire if this is known issue in this model--all these companies keep extensive records or model versus problems.
One possible solution to access the service menu on LG tv's is as follows with steps 1 - 4:
1. With the TV on, press and hold the MENU button on the TV front panel. 2. While holding that button, press and hold the MENU button on your remote. 3. Hold both buttons for ~5 seconds until the service menu comes up on the TV. 4. Release the remote MENU button first, then the TV MENU button.
If you are looking to reset the lamp indicator then continue with the following steps 5 - 11:
5. Press and hold the ENTER (or OK) button on the TV front panel. 6. While holding that button, press and hold the MUTE button on the remote. 7. Hold both buttons until the Lamp Life Hours show up on your TV screen. 8. Release the MUTE button first, then the ENTER button on the TV front panel. 9. Make a note of the lamp hours if you want. 10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote. 11. It will ask you to confirm the reset--press SELECT again to confirm.
To verify you've reset the hours, you can repeat steps 1-9 above and then just press the EXIT button on your remote.
Shut unit off. Wait 10 to 15 seconds then press and hold volume down and channel down together for 10 to 15 seconds. This will get you into the service menu.
Some say you can reset the timer in the service menu, normally accessed by holding down the menu button on the TV and the mute button on your remote at the same time. Others say you need a special "service remote" to access the timer. I've changed my bulb twice already and have just learned to ignore the amber lamp timer light. A little square of black electricians tape would make it go away!
