SOURCE: Samsung frontloading washer won't dispense fabric softner
clean filters in washer inlets on back of washer. take off hoses and look up inside of inlet, pull out the filters by pulling stright out on them. then fush backwards to get sand or whatever out of fiter
SOURCE: water leaking out of front of washer at soap
We had this same problem...I wasn't using a garmet bag and turns out, one of the hoses were clogged with a small pair of underwear then again with a childs sock. Take the casing (top of the washer) off... and take a look at the hoses etc.
SOURCE: Water is pouring out of the detergent dispensing
Pull the drawer out you will find detergent has built up in side the dispenser probably from from way too much detergent, modern front loaders work best with a small amount of detergent and liquid detergent normally will wash better.
SOURCE: my samsung washer is leaking
strange. see if the tray is broken. the water shouldn't be out.
Daniel
