John deere 2440 series hydraulic system creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
have not operated this tractor and I need to know how the control panel etc works as I am starting a new job and need to know
john deere 2140 hydraulic problems
