Often times the inner hub of the rim seizes up in the spindle. use the wd40 on the studs and the rim hub and let sit for an hour then your going to have to use you foot to kick the tir on the top and the bottom of the tire untill it works loose. also have somehelp you by using a big sledge hammer to hit the back side as you hit from the front of the tire this will work quite well. in no time tyhe tire and rim will come off . then use a anti seize on the spindle hub not on the studs when you replace the tire.
