Craftsman 24 Hp 48" Deck Yard Tractor Logo
Posted on Apr 18, 2009
Craftsman yard tractor runs but take foot off brake it dies.....
Have Craftsman yard tractor it starts and stays running, as long as I keep my foot on the brake.  Once I lift my foot of the brake it dies, like running out of gas.  This also happens when I try to engage the blades.
Is there some tensioner or pulley I should be looking for that is causing the problem?  I looked underneath while my wife pumped the brake pedal and moved the blade engage thing but didn't see obvious breaks or anything.
HELP PLEASE!!!!
Thanks
Jerry
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Apr 21, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
966
Points
8
Check the under seat switch. The switch sometimes fails and this cuts the ignition except when the foot brake is down. You can use jumpers across the switch wires to test it.
  • Anonymous Apr 03, 2013
    thanks bud , that worked a treat
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 03, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
557
Points
Lads thanks for all the replies , it was the switch under the seat was ceased , i dismantled it ,wd 40 and reassembled it and now my problem is fixed . my mc cullagh ride on 42 , started , but as soon as i decompressed the brake whilst in gear it just knocked off , or if i engaged the pto the same thing happened .
now working fine . thank you guys
Anonymous
Level 1:
New Friend:
  • Posted on Jun 09, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
557
Points
I have a 2002 craftsman that did the same thing. The problem was the connection from the chassis harness to the motor harness. It would close the plunger on the Carb cause it didn't think the driver was there.
Small farm tractor starts won't stay running
sounds like the carb has some bad gas in it or it may have some trash in it plugging up the jets
16 hp Craftsman starts and runs fine until u take foot off brake, then dies
is there a safety switch on the seat? Many of these tractors have all this safety **** on it if it senses you are not sitting on the seat, it will shut off if in gear and foot off brake
My 42 in Craftsman Tractor will not start. It normally runs great. I went to start it the other day and it ran for about 5 seconds before shutting down. It felt like it was getting no fuel. Any...
try and run it with the gas cap loose the vent could be plugged also see if it cuts out while keeping you foot on the brake and its just a bad safety switch shutting it off
My Craftsman 42" 18.5hp lawn tractor will start fine but when I disengage the brake or engage the blades it cuts off. It was recently left out in the rain while I was working, did something short out? It...
there is a safety switch under the seat. to stay running after the brake is released or deck engaged you have to be sitting on the seat or it will die. if this switch is bad it will die as soon as you release the brake.
Won't stay running when i take my foot off the brake pdl
It is caused by the safety system - the seat switch, or the wires and connections going to it, cause this problem. Lift up the seat and look to see if the seat switch mounting has come loose or is broken. Make sure the connectors on the seat switch are on tight. If all that looks OK, take the seat switch out and use tape to keep the plunger pushed in. If that fixes it, then the switch mounting is the problem. If that doesn't fix it, then replace the seat switch itself - it's not expensive.
My Craftsman 26hp tractor is running extremely ruff, I have replaced the plugs Confirmed that the plugs are working. It runs ruff at all speeds. The tractor was runing just fine a few weeks ago
You've changed the plugs have you checked the oil and air filter if not you need to because if not it might need changed and it may be low the rider my father gave me ran ruff and would die in 5th gear and I changed the oil and air filter now it stays going in all gears.So my suggestion to you is to to change the oil and air filter I am not a pro but I have had to keep my mowers going no help from anyone so I had to learn so if you don't agree with me check with a repairman.
Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
Tractor won't stay running
You will have to pull the carburetor off and rebuild it. This means cleanig and adjusting. This should help your cause a bit. donnyb60
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
