Seven blinks - High voltage shutdown. The high
voltage has exceeded 33k and the unit goes immediately into safety shutdown.
Check power supply regulation and horizontal circuits. If you wish to get more details, check this site. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or
type in the brand name and model number to of your set, to its
search box, and press 'Enter' or view it in Mosaic /
Timeslide option.
SOURCE: standby blinks 7 times
The part # for the d board is A-1300-319-A pts corp can rebuild it for about $250 www.ptscorp.com
SOURCE: Sony FD Trinitron WEGA KV-34HS510 34
SOURCE: the standby botton blink 7 in my sony trinitron
Seven blinks - High voltage shutdown. The high voltage
SOURCE: My KV-36HS500 doesn't turn on.
You will need 2 MCZ3001D or MCZ3001DBs and two 18 pin IC sockets. the chips are on the d-board inside the tv.
SOURCE: standby light blinks 7 times and tv will not turn
Thanks for using FixYa. Standby
light blinking 7 times means high voltage shutdown. The high voltage has
exceeded 33k and the unit goes immediately into safety shutdown. You’ll need to
check power supply regulation and horizontal circuits. Please do accept the
solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
