Does anybody know how to replace the motor? What are the steps? Any pictures?
On my Kenmore bottom freezer, the evaporator fan motor is located behind a grill in the top center of the freezer compartment. Remove drawers and door. Pop off the grill by pushing on the tab in the center of the grill and then dislodging one side. If you see the fan and confirm it isn't working, then you will have to remove the icemaker. Disconnect the plug at the rear of the icemaker by pressing on both sides of the plug and pulling. Then remove the three screws holding the icemaker and remove the icemaker (it will probably have water in it, not ice).
Push the icemaker female plug through the back panel.
Remove the temp sensor cover on the upper right side of the panel. Careful. You need to pop the cover loose, then slide the cover off the sensor.
Now remove the four screws holding the back panel and remove it. Try not to let the panel hit the evaporator fins, which are directly behind the panel. Also, you'll have to be careful to work the temp sensor up over the top of the panel.
You have clear access to the evap fan now. Unsnap the temp sensor from the tubing on the right. Disconnect the evap fan wiring (left side) and another connector on the right. Remove two screws, and you have the evap fan assembly in your hand. Pull the fan blade off the motor shaft (friction fit) and loosen the motor retaining clip.
Voila! You have the old motor in your hand.
Good luck.
KentC
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
UNDER COUNTER ICE MAKE HAS BAD FAN MOTOR BUT NOT SURE HOW TO GET FAN MOTOR OUT. M-10689482995. GLEN
