SOURCE: MY NIKON 550 RANGE FINDER
Same problem. Conclusion: just because it has the NIKON name does not mean it is not a piece of Chinese junk.
SOURCE: I have a nikon LR 1200 golf range finder that will
Hi Bobby,
This seems to be a problem with the laser alignment , which has gone out of order due to change in temperatures and other external factors.
I would suggest you to reset your device , by removing the batteries for at least 5 mins and then putting them back in.
Also make sure there is no blockage in front of the rangefinder , like a strap for example.
Changing the targeting mode can also help you remove the problem , try doing it.
If this does not work , then in such cases people either like to repair the device or get a new one , by comparing the cost that is incurred.
Hope this helps ...:)
