SOURCE: i need a belt diagram for a 60 inch Swisher lawn
There is a good repair manual here:
http://www.manualnguide.com/dl/3425/
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
SOURCE: I need a cable for swisher mower 60 in deck , cable supports cutting deck and helps level deck
Buddy of mine is a Swisher dealer give him a call 1- 920 - 841-7654 This is a Wisconsin number Im sure if he has one he can ship it or give you a name of someone closer.
SOURCE: how can I put more tension on the belt of my 44 inch swisher trail mower
I would try replacing the spring
