Call your Ford dealer and ask them if you car has a locking steering wheel.
Since "forever" ago, there was a were "star wheels" attached to the inside of the steering column, for the purpose of preventing theft by locking the steering wheel when the key was removed.. The bad side was that those locks can jamb if the steering wheel
is at the end of it's travel, such as can happen if the front wheel of the car is jammed against a curb when parked.
Your fix might just be to turn the steering wheel whilst trying to start it, though it may take a little muscle.
God bless your efforts.
The whining noise means the pump is cavitating--sucking air. It probably needs to be bled as stated by others. Several of the Garden Tractor forums have manuals for download, or you can post a question and get an answer from someone that has experience with your machine.
Have you checked the power steering fluid level? The reservoir for the fluid will be at the front of the engine, where the belt runs the power steering pump. If it's low or out add a little power steering fluid till full, then start car and slowly turn wheels back and forth from stop to stop-not too ******* the stops (when the steering won't turn further that way...that's what I mean by stops)....Turn wheel one way full travel, then reverse and turn the other way. Check the fluid level again, and add as needed.
If fluid is not low, the belt may be too loose to make the power steering pump work, or you may have a bigger problem that needs professional attewntion.
It does if it has power steering. They came both ways. Power steering is pretty easy to tell if you have it or not. If you don't have it, you will need two hands for sure to park the car in a tight spot, the steering wheel is quite hard to turn compared to other cars with power steering.
1991 ford power steering pump after replacement should be bled off.you should rev the engine to about 2500 rpm before pump starts pumping and then turn the wheel from stop to stop several times.make sure the fluid is clean .if that doesnt help u need a box.
I would check for leaks. After the car sits overnight look undernieth the cor on the drivers side. You are most likely going to see a tiny puddle of very thin oil. Check the tubing connections at the pump (mounted to the engine on the drivers side) and the front axel. Be certain to use Mopar power steering fluid when topping off. You may also need to get any air out of the system. Jack up the car so that both wheels are off the ground. With the engine turned off, turn the wheels to left and right lock positions a couple times. Lower the car, top off the fluid if necessary & give it a drive. Hope that works for ya.
