The most common reason why your towels are hard to scratchy because there are low grade Walmart a good quality tile will do you need to purchase better quality don't play the washing machine you need to buy a better quality towel
Limit bath time. Hot water and long showers or baths remove oils from your skin. Limit your bath or shower time, and use warm - rather than hot water.Avoid strong soaps. Strong soaps can strip oil from your skin. Instead, choose mild cleansers. Pat dry. After washing or bathing, gently pat or blot your skin dry with a towel so that some moisture remains on your skin. Moisturize dry skin. Find a moisturizer that fits your skin type and makes your skin look and feel soft.<br /><br />
Hi Steve, This is usually caused by an uneven load. For instance, If you have a bath towel in with some shirts or tea towels, the bath towel absorbes more water than the tea towels, thus making an uneven load.
My wife tends to wash slippers in a pillow case with nothing else in the washer, and the drum will bang against the side.
Hope this helps
This washer is a Kenmore HE2 Plus. Per Sears: "Wash more at once - 3.6 cu. ft. capacity cleans up to 18 bath towels in one load (Based on approximately 24 in. x 44 in. bath towels)"
Don't ever use fabric softener again. A woman in the Westpoint Outlet told me that years ago...never use fabric softener on your bath towels, it makes them water resistant.
take it off and bathe it in petrol then use a new paintbrush to clean it. give it a good dry and polish with a soft piece of towel (NOT PAPER TOWEL). dont forget to put a new gasket on when replacing it. :)
hi, you may find that the towels when wet are to heavy for the belt to grip the drum if it spins with normal clothes in you need to reduce the load when you wash your towels, hope this helps.
