I have a Crystal Cold propane refrigerator and freezer CC18. Freezer is fine but the refrigerator freezes even with the thermostat almost to defrost.
SOURCE: Not getting cool enough
this sounds like a compressor problem. if the outside coils are getting hot (and properly ventilated) but the inside of the unit is not getting cold then the heat is coming from the compressor.
SOURCE: not working on ac on propane freezer gets down to
There was ohm resistance there, but not a lot. After removing the heating element it only gets hot in about a 3" area of the tube/element. Transfer of heat was present but not a lot, you could touch it anywhere on the tube but in the 3" area. A typical hot water heater element either works or it doesn't meaning it it "open" but his has me baffled as I can't find any specs as to how many ohms it should read.
cooling unit is bad my friend there is a temporary fix but in my opinion not worth your time take the unit out and flip the refer upside down this sometimes dislodges the blockage in the cooling unit all a rv fridge is is amonia and salt if not used all the time the salt crystalizes in the orfice and blocks the unit a rebult cooling unit 550 about and labor 4 hours at your dealers rate a new fridge about 1500 installed
my shop 360 for labor 550 about for unit 910
I ALLWAYS RECOMEND REPLACING THE FRIDE COMPLETLTY
you get all new electronics and a new box
SOURCE: the freezer seems to be working fine but the
If you want a service manual for a Dometic Brand click on the link below. They are good people they will help you.
http://www.gasrefrigeration.net/dometic_manuals.htm
Aug 06, 2009- If I can help you let me know, I work and talk to Dometic a lot, Thanks Sea Breeze
[email protected]
Mine has a similar problem. Could it be a defective thermostat?
