SOURCE: Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
SOURCE: Sharp R-9H56 Microwave convection oven
I have this model. Press clear then press Auto/Clock. Enter in the time eg 700 then press Auto/Clock again. The time should now be set
SOURCE: The microwave suddenly beeped several
The code f3 is a short in the key pad for more than 60 seconds
go to GE .com and enter your model # and you can get a price to do it your self
Good luck
TEETERMAN
SOURCE: Panasonic microwave touchpad not working
The
first thing I would suggest is a hard reset. Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
You may instead have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this for you, we do that for $39.95 plus part costs, which depends on the exact model, one of these:
NNS688BA NNS688BAS NNS688LA NNS688LAS NNS688WA NNS688WAS
Please feel free to contact me directly if you need more help.
SOURCE: GE Microwave displaying --F3--
F3 on a GE / Hotpoint
microwave means you have a shorting keypad / controls.
There's a chance it can come on by itself and run unattended, which can result in a fire.
So until it is repaired,
please leave it unplugged or leave the door
open.
On this model, the keypad is not available as a separate part, so you would have to replace the entire controller assembly.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Then you disconnect the wires and install the new controller.
You can order part number WB07X10903 here for $114.37 (compare that to $174.75 direct from GE!).
We're
