HELLO Anonymous,
I think you are having a basic PROBLEM with
the idea that FREE ADVICE could actually
be valuable...
You need to make up your mind...
If "NOTHING will FREEZE"...
Then how in the world could it
"seem to DEFROST" ...??
(bull-feathers)
What you are saying is contradictory nonsense...
I can totally ASSURE YOU an 80°F or 90°F degree
ambient temperature would have very little effect
on a WORKING REFRIGERATOR...
Think Fresno, Bakersfield or Mojave
(and get over it).
I come here daily... If YOU want to get serious
about your REFRIGERATION ISSUES...
I love refrigerators... and stop by DAILY...
Get serious about your symptoms...
Buy the applicable TAYLOR thermometer
and MONITOR precisely of WHAT YOU SPEAK...
Together.. We can do this...!!
Buy & use this ($6 refrigerator thermometer):
https://www.amazon.com/Taylor-Precision-Products-Thermometer-Refrigerator/dp/B000BPE88E/ref=sr_1_14?ie=UTF8&qid=1507620811&sr=8-14&keywords=taylor+thermometer
We can do this (if you wish)
Carnac the Magnificent
SOURCE: Power is on but nothing is working, not cold ,no water, no ice
Sounds like the unit needs a reset of sorts, Get your food into another refrigerator or ice chests and unplug the unit. let it stand open for several hours (just in case the vents are iced) and then plug it back in.
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
SOURCE: GE Profile refrigerator freezer remains in defrost mode
once it go to defrost the fan in freezer will be off when it come back to freezing should be on some takes a second or two and then fan come on check fan switch
SOURCE: Freezer does not freeze fast enough, icecream gets soft
Faulty Cold control (Temperature Control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
If the control is not closing, the compressor and all fans will cease to operate. Check the control for continuity.
This is usually not a do it your selfer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: The refrigerator temperature keeps dropping
I had the same problem with my GE GSS25LGMB and after some googling I learned that the damper door might be broken. Indeed after I took off the damper assembly the door appeared to be broken at the hinge. This door has its own thermostat and controls the influx of cold air into the fridge which explains the frozen food. I am trying to glue the broken piece back on. See if it works. Othwersie you'll have to replace the entire damper assembly which costs about $91. (http://www.pcappliancerepair.com/cgi-bin/detail.cgi?item=WR49X10091&brand=GEH)
