Lifetime 3819 Impact 44" Basketball Backboard & Rim Combo Logo
Richid Posted on Sep 13, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I repair a crack in the backboard? - Lifetime 3819 Impact 44" Basketball Backboard & Rim Combo
Larry
Level 2:
Sergeant:
  • Expert 288 Answers
  • Posted on Sep 13, 2013
Larry
Expert
Level 2:
Sergeant:
Answers
288
Questions
0
Helped
55696
Points
528
I have a Spalding 60 inch glass basketball system. It was lowered all the way down and now it can't be raised because it's too low. How do I fix this?
In-ground Basketball Goals: Spalding 88369 NBA ...
www.atlantahoops.com > In-Ground Basketball Goals
The Spalding 88369 NBA Inground Basketball Goal System includes a 60'W x 36'H Pro style extruded aluminum framed Tempered Glass or Acrylic backboard ... Click here to download the Spalding 88369 Basketball Goal Owner's Manual
1helpful
NEED PART NUMBER FOR STIHL LEAF BLOWER MODEL BR380 FOR THE BACKBOARD PAD REPLACEMENT
Previous model PN 4203 790 8001
Current model PN 4203 790 8003
Huffy center court replacement backboard
you can go online like to ebay or some other dearler ship and search huffy center couter or (backboard) and there you go. Also its cheap
Mar 16, 2013 • Basketball
Broken tempered glass backboard
Garage/yard sales, craigslist. Do you know someone in the neighborhood who hasn't used theirs for awhile, Ask them if they will take $50 for theirs that may be in the way.
7helpful
2answers
I am getting an E3 Error message on my temp
Do this...
The e3/e4 problem is the "connectors" for the fans to the middle separator shelf are put in the pathway of condensation. This causes them to get wet and rust. PLEASE NOTE: If you decide to attempt this fix, you take full responsibility for your fridge and the outcome. If you don’t think you can do this…DON’T! Call a licensed electrician. Here is how I resolved my e3 issue: 1) Unplug the fridge
2) Remove all wine and the metal shelves
3) Remove the 2 screws from the middle separator shelf, one on each side on top
4) Remove the 4 screws from the backboard, one in each corner
5) Slide out the middle shelf slowly, on the right hand side towards the front of the shelf there will be 4 connectors you must disconnect before removing the shelf (they are tucked into the shelf). With one hand on the backboard and one on the shelf, slowly take them out together
6) Once you have the backboard and shelf out, you'll see there is a black and white connector, each having a red and black wire on each side
7) These are the fan connectors that are causing the issue. Mine were brown/green and damp (not good for electricity)
8) Using wire cutters, cut as close as possible to the "black" connector on each side to remove it. You will have 4 wires left, 2 from the backboard and two from the shelf (both having a red and black)
9) Take some of the sheath (cover) off of each wire
10) Take the red wire from the backboard and the red wire from the shelf and twist the metal portion together
11) Cover w/ electrical tape!!! Or you will have the same e3/e4 issue
12) Repeat step 10 and 11 for the black wires
13) Move onto the "white" connector and repeat steps 8 - 12
14) Put the backboard and shelf back in the fridge. Be careful not to pull the backboard and shelf apart or your connection may come apart
15) As you slide the shelf in, make sure the wires you disconnected in step 5 are in the "channel" on the side of the shelf or the shelf won't slide properly.
16) Reattached the 4 connectors and then re-attach the backboard and the shelf with the screws
17) Plug the fridge back in
18) Put the metal shelves and wine back in
29helpful
E3 error message on Magic Chef wine cooler MCWC44DZ. Can I fix it myself?
Taken from another poster at Home Depot reviews and similiar to what others have found...
" Sucks that a $0.10 piece of heatshrink on the connectors could avoid this...? Bad Design.
Basketball pole
Ihave a pole and backboard but my backboard is cracked badly. Would you consider selling yours?
1helpful
2answers
Basketball backboard problem
well it is probably a cheap backboard then. sorry
Top Lifetime Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Lifetime Sport and Outdoor - Other Expert? Answer questions, earn points and help others
