RUSTIN...RUSTIN...RUSTIN! I presume water is still in the Tub? Thought so...OK "IF" your Drain Filter, hose, and house plumbing are Clear...(Are They?) then it is your Drain Pump. Circuit Boards rarely go out and unless you are cutting wires, they don't fail either. A pump will, it either works...pumps OUT the water OR it doesn't. If it doesn't then the tub fills with water, STOPS, and goes on Strike! No it will not spin cause your machine would end up on the sidewalk thumping and clankin all the way! Change the Drain Pump. UN-PLUG DA MACHINE FIRST!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
First try cleaning the moisture sensors with rubbing alcohol,
these are two silver colored strips located inside the drier just below the
lint cleanout
