Question about Pride New Mobility Legend 4 Wheel Scooter
Had a problem with my free wheel Assembly now it won't charge any ideas??????
Mobility scooter beeps but will not move
The 5-beeps indicates you are in free-wheeling mode. If the free-wheeling brake disengage lever is in the correct position then you likely have a bad brake switch or bad brake coil assembly.
Verify free wheel lever is in correct position and Replace the bad component if necessary.
Mar 10, 2014 | Health & Beauty
Volvo s40 2008 won't start, battery fine, clicking noise
When you get it started take it to autozone or kragen they can wheel a machine out to the car and test the starting system and charging system for free.
Jan 15, 2013 | YouTube Videos
Old Pride Rally won't charge or run
The batteries may be too old to take a charge. They are gell cell types and can be had at any battery shop. You can get them on line too, but shipping will be high.
Dec 19, 2012 | Pride Rally 3 Wheel Scooter
My 2005 Chevy Malibu it won't start, or even turn over. .
Have you replace battery, had charging system checked? there is a fan motor resistor assembly that has the speeds. the hi runs directly from car electrical, replace resistor assembly . an auto parts store has them, They may also check your charging system.
Jul 17, 2017 | 2005 Chevrolet Malibu
One wheel on my Pride Jet 3 won't go.
Have you ever solved the problem? My Jet 3 does the same thing and i would like to know whats causing it.
Thanks
Rangr90
Jan 08, 2012 | Pride Used Mobility Jet 3 Power Wheel...
Bugaboo Bee 2009 back wheel won't come off
Not sure if your problem is removing the Hex bolts or pressing the axel out. Either way what you have tried is all you can do at home. Pop down to your local engineering work shop. They can press is out in no time. Max they'll charge is half an hour around $40 they may do it for free if in a good mood.
Nov 05, 2011 | Bugaboo Bee Umbrella Stroller
Son's 2000 blazer has high pitch noise and battery dead--charged battery and had checked they said it was good battery. what could be wrong? won't start clicks
your starter assembly has a problem check the solenoid its cause of hard starting replace it or replace starter assembly.
rate me if you can thanks:
Jun 11, 2011 | 2000 Chevrolet Blazer
Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Jun 27, 2010 | Electric Mobility 3 Wheel Motorized...
I would like to know if the wheel bearing is in the shaft or the hub?
The Constant Velocity (CV) joints are located on the inner and outer edges of the axle shaft. The axle shaft runs through the hub and bearing in the spindle.
Jun 16, 2010 | 1999 Daewoo Nubira
Pride New Mobility Legend 4 Wheel Scooter Logo
23 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
