Question about U-Line ?chelon 2175RB-00
How to bypass thermostat on U-Line refrigerator
Water comes out real slow from dispenser. we put by pass in and still slow.
When you say you put a bypass in, are you referring to a bypass for a water filter? Make sure there isn't a filter that was already in the line outside the refrigerator or, if that's what was bypassed, make sure there isn't another filter in the refrigerator.
If you're positive that the filter isn't the issue you may need to disconnect the water line and check for debris in the connection to the refrigerator, then confirm you have good water pressure to the fridge.
Nov 21, 2016 | Refrigerators
My caravan 3 way fridge has stopped working. all electrical connections are intact and working. likewise the gas connection is working and lights correctly.controls as to energy source and thermostat
Most rv refrigerators are much the same. Since I don't know just which one you have I can at least guide you to youtube where there are some good videos about troubleshooting rv refrigerators.
Keep in mind that since you have a three way refrigerator you can connect the line voltage directly to ac heating element and bypass all of the electrical circuits to prove that the refrigerator will work or not.
rv refrigerator troubleshooting YouTube
Sep 26, 2014 | Refrigerators
Can i bypass the defrost thermostat until i can get a new one
take a hair dryer and defrost the coils totally this should keep you for a week or so.
turn the ref off and do it,do not hot wire it,you will melt the liner,dangerous.
Apr 27, 2014 | GE Refrigerators
Won't cool
Sounds like an issue with your compressor no starting. You should ohm out the windings on the compressor
Feb 26, 2014 | U-Line 29R Compact Refrigerator
How to bypass refrg thermostat
I believe this an electronic verstion if so not able to jump
Jun 16, 2012 | U-Line ?chelon 2175RB-00
Where are the switches to the fans? I think mine are bad, that is why the fan will not turn on
These are always going bad...it is the defrost thermostat thats go bad or your fan motor..the defrost thermostat is located behind cover in freezer...one side is connected to your heater and the other is the line wire....you can actually bypass the defrost t/s just to check it, however, check for voltahhhhge at fan first
Jan 20, 2011 | Amana ASD2622HRQ Side by Side Refrigerator
I have U-line Model #75RB-00 Refrigerator, the motor does not run and no cold air, light does work
If your motor and compressor isnt running then replace the control. If the compressor tries to run but kicks out then you need to replace the fan. You can always bypass the thermostat to check everything before you guess at it.
Oct 01, 2009 | U-Line ?chelon 2175RB-00
Chefmate mini fridge no more
OK If this is a U-line refrigerator. Is the compressor running? The Fan? If both are running then you will have a sealed system issue. If nothing is running then it goes to the thermostat. Bypass the 2 wires from the thermostat to see if it runs.Yes, then replace the thermostat.
Jul 21, 2009 | U-Line 15R Compact Refrigerator
Describe your uline wine cooler Problem ULINE WC2015: Light comes on but unit won't run. Cleaned as discussed in owners manual. Need help!
OK if you have a 20 series and you have a light and no fan or compressor then you need a thermostat. This will have 2 wires to it and if you bypass the thermostat the unit should run. If it does then replace the thermostat
Jul 18, 2009 | U-Line Wine Captain (2015WC) Wine Cooler
U-Line ?chelon 2175RB-00 Logo
46 people viewed this question
Top U-Line Refrigerators Experts
Marvin
Marvin
ray gallant
brokenrubber
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
