Cannot get sound to my 7.1speaker setup either by Radio, CD, DVD via the Onkyo AV Receiver all connected via HDMI. I can only get sound on Zone 2 via the radio. I notice the HDMI flashes on the receiver. It not the dvd player or hdmi cable as it works fine connected directly to the TV.
Dvd connection is set to HDMI1,
I even tried a factory reset, but same problem.
Please help.
The posabilities is power amplifier on your reciever is bad,
replays reciever or repair it.More likely this is IC amplifier located on the main board of the reciever
I had the exact same problem. I fixed it by resetting to factory settings: While receiver is turned on, press and hold down VCR/DVR button, then press ON/STANDBY button. Make sure you write down your current settings, so you can easily go through the setup after resetting.
I got the same problem today after using this receiver for over 6 years. Resetting to factory setting did not help. No sounds through speakers or headphones, on all inputs including radio tuner - not even static noise. HDMI is blinking too. Current workaround is to plug everything directly into HDTV and using TV's speakers, but need to find out how to fix my Onkyo receiver too.
If it's any relevant, when I plug in setup mic the receiver goes into Audesey mode, and says "press enter: next" but pressing enter has no effect.
Not a solving of the problem, just not sure how else to post on here but I have the exact same problem. it was working fine and all of a sudden i get no sound out of my receiver. Everything works fine if connected directly from tv/dvd and tv/cable box.
Were you able to find a solution?
SOURCE: Audio Problems
See www.avforums.com/forums/onkyo-owners-forum/696423-faq-setting-up-ps3-onkyo-amp.html
This should give you the info to set up the ps3.
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
SOURCE: Onkyo TX-SR606 getting no sound from HDMI sources
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Hi, thanks for you advice, since posting this, sound has come back but its an intermitting problem, sometime it works and sometime it doesn't, like it has a mind of it own. When it comes back it will play for hours without problems if you had to leave it on radio, when you switch it of and back on again, no sound.
Can this still be the IC amplifier on the main board.
