Is you oil at the correct level? When you drained your oil did you find any ferodo or metal remains in the oil? Are you getting 0 psi from the test ports? Is your inching valve ok (attached to the brake pedal)? Is your brakes jammed on? Check your half shafts 1 could be broken? Are the fwd/rev solenoids getting power when a gears selected? If its mechanical is the lever moving the spool?
