Carrier 5 Ton Infinity High Efficiency Outdoor Ac Condenser Unit Logo
mark breshears Posted on Sep 07, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It will not say on unit what the kbtu is? - Carrier 5 Ton Infinity High Efficiency Outdoor Ac Condenser Unit
Brian Mills
Level 3:
Master:
  • Master 613 Answers
  • Posted on Jul 11, 2014
Brian Mills
Master
Level 3:
Master:
Answers
613
Questions
0
Helped
133292
Points
1126
There is 12,000 Btu of cooling per ton. 5 tons = 60,000 BTU
2helpful
3answers
LG 3 Zone Mini Split AC. Unit shutting off and displaying CH35 low refrigerant.
Find a new AC engineer approved by LG. All AC Units leak a small amount at the compressor bearings and seals. It sounds like yours needs some sealant. and gas, or a new sensor. Diagnosis by an LG trained engineer is needed.
https://www.google.com/search?q=3+zone+LG+mini+service+engineer
How many megabytes = 1 Gigabyte
1024 MB = 1 GB
This is due to binary (2*2*2...) multiplication.
In most other everyday measurements, it is calculated as power of tens.
List from Greek words, used for multipliers:
femto = f = unit / 10^18?
atto = a = unit / 10^15?
pico = p = unit / 10^12
nano = n = unit / 10^9
micro = u = unit / 10^6
milli = m = unit / 10^3
centi = c = unit / 10^2
deci = d = unit / 10^1
Deca = unit * 10^1
Hecta = unit * 10^2
Kilo = K = unit * 10^3
Mega = M = unit * 10^6
Giga = G = unit * 10^9
Tera = T = unit * 10^12
Peta = P = unit * 10^15?
Exa = E = unit * 10^18?
Note: extreme values femto, atto, Peta and Exa seldom used except in laboratories. Can't remember order of these marked '?'.
Will look it up and edit if necessary.
Other used in electronics, electrical, weight, measurement, distance, speed, temperature, etc.
The symbol is always the prefix, followed by unit.
Case of letters is important.
ml for milliliter, but MHz for Megahertz.
Km, Dg, dB, Tb/sec, EV...
What boards are applicable on OSN 1500B?
List of cross-connect board Q2CXL1 1xSTM-1 SCC unit, cross-connect unit, timing unit, and line unit integrated board Q2CXL4 1xSTM-4 SCC unit, cross-connect unit, timing unit, and line unit integrated board Q2CXL16 1xSTM-16 SCC unit, cross-connect unit, timing unit, and line unit integrated board Q5CXLLN 1xSTM-16/STM-4/STM-1 SCC unit, cross-connect unit, timing unit, and line unit integrated board R1CXLLN 1xSTM-16/STM-4/STM-1 SCC unit, cross-connect unit, timing unit, and line unit integrated board R1PCXLN SCC unit, cross-connect unit, optical interface unit integrated board Search SCC
1helpful
What is kbtu
That would need to come from the manufacturer.
31helpful
On one of our two parent receivers, it's showing 1 red light with 4 green lights above it. No sound at all. The other parent receiver works just fine, perfectly clear. I think my toddler was playing...
I had the same thing happen to one of my parent units over the weekend. The issue is that the parent unit lost the pairing with the nursery unit. Once I re-paired them, it's working great again. This is in the Troubleshooting part of the manual, but I've copied below for your convenience.
If Parent Unit won't lock onto the Nursery Unit, or you purchased a new Nursery Unit, follow the procedure below to pair the Parent Unit and Nursery Unit. If you purchased a new Parent Unit, skip Step 1. The new Parent Unit is ready to pair with your Nursery Unit.
1. Erase the Pairing from the Parent Unit. Turn the Parent Unit off. Hold the Volume Down Button on the Parent Unit while pressing the On/Off Button. Continue to hold the Volume Down Button until you hear a single beep and all of the Sound Lights illuminate briefly. Release the Volume Down Button. Press and hold the Volume Down Button again. Within 2 seconds you will hear a beep. Release the Volume Down Button. All of the SoundLights and the red Loss Connection LED will be lit. The Parent Unit is ready to pair with Nursery Unit. 2. Pair the Parent Unit with Nursery. Place Nursery Unit in the same room, five (5) feet (1.5 meters) away from the Parent Unit. Turn on Nursery Unit using the On/Off Button on the side. The green power light should come on. Within a few seconds, the Parent Unit will find the Nursery Unit. The SoundLights will shut off and the Parent Unit will beep. The Parent Unit is now paired with Nursery Unit. 3. Repeat this procedure if you need to pair another Parent Unit with the Nursery Unit.
Nothing happened when I turned on the Nursery Unit. What do I do? First try turning the Nursery Unit off, and then on again. If the Parent Unit still does not pair with the Nursery Unit, press the Channel Button on the Nursery Unit, then turn the Nursery Unit off, and then on again.
Hope this helps.
How to write an electricity bill in c program(9'th class)
#include <iostream.h>
#include <conio.h>
int main()
clrscr();
long int units,charge=0;
float total;
const int rent=25;
cout << "Enter the number of units used : ";
cin>>units;
if(units>200)
charge=(units-200)*20+150*40+50*60;
else if(units>50)
charge=(units-50)*40+50*60;
else
charge=units*60;
total=0.01*charge+rent;
cout << "You have used " << units << " units." << endl;
cout << "Your total telephone bill is $" << total;
getch();
return 0;
Please accept the solution. Thanks, Lucy
This program takes in the number of units used ('units') as a screen input from the user.
It then calculates the total telephone bill for the customer on the following basis :
A compulsory fee of $25, plus
60 cents per unit for the first 50 units,
40 cents per unit for the next 150 units,
20 cents per unit for anything above 200 units.
It then outputs the bill using the 'cout' command.
Correct eec for 1989 ford f150 5.8l
Here is a listing of all possible computer modules for that truck. Perhaps this will help in some way in your search.
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AL1A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AL1B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AL2A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AL2B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-ALA
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-ALB
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AN1A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AN1B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AN2A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AN2B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-ANA
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-ANB
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AP1A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AP1B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AP2A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AP2B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-APA
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-APB
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), High Altitude
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AK1A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AK2A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E9TF-Z1B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E9TF-Z2B
12helpful
2answers
The parent unit does not recognize that the nursery unit is on. all the correct lights are displayed on the nursery unit for normal function, but the parent unit display indicates that the nursery unit is...
Sounds like the units need to be paired. Start with all units off. Then turn on one of the parent units. Press and hold the menu button until it beeps. Quickly turn on the nursery unit and press and hold the button on the nursery unit that has the parent unit icon below it. After a couple of seconds the units will pair. Repeat this process with the other parent unit.
I'm looking for a service manual for a Sharp AR-C160 Color Copier & Setup instructions for the sorter/stapler. Yes, I've found them online several places for a price, but why should we pay for them?
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
AR-S160(Japan only )
AR-160(Except Japan )
MODEL AR-161(Except Japan )
Exteriors
Operation panel section
Side door unit
Optical unit
2nd,3rd mirror unit
Middle frame unit
Process unit
DV cartridge unit
Fusing unit
Main drive unit
Base plate unit 1
Base plate unit 2
Manual paper feeding multi unit
Delivery frame unit
TC case unit
250 sheets tray unit
Packing material & Accessories
MCU PWB
I have this one, but i can't send a file writ to me to [email protected]
3answers
GOLDSTAR AIR CONDICION (WALL UNIT) MODEL # BG8000ERY3
Download it from the manufacture webpage and the model #.
Top Carrier Air Tools & Compressors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Carrier Air Tool and Compressor Expert? Answer questions, earn points and help others
