Won't start has oil leaking from exhaust
SOURCE: cannot start ryobi 3043 yw grass edger
Check the spark plug and sheck the gap on it then check the wire
SOURCE: My Ryobi PLT 2543 strimmer will run, but cuts out
I had this problem twice in the past. I solved it the first time by replacingthe plug and setting the plug gap with a feeler guage. The next time it was a decoke of the cylinder (squirting through the plug hole) replacing the plug and leaving it overnight and then cleaning the air filter. It runs like a dream and has worked in Australia, Europe and the UK with no further problems. Also the fule mix has to be just right, I actually use 22:1 instead of 25:1 and do not use any petrol / gas with additives in (like Shell).
SOURCE: I want to access the pull cord
This appears to be a model only sold in the UK but it looks like the standard, Ryobi,Homelite,Toro, trimmers we have in the states. You have to remove the 4 screws that hold the motor to the shaft to access the recoil starter. Once apart it will become evident how to remove the starter parts. Hope this helps.
SOURCE: need service manual for ryobi
Here is a PDF file of an owners manual the closest I could find to your listed model. You will need Adobe Reader installed on your computer to view this. It is a free and safe download from Adobe.com.
http://dl.owneriq.net/6/62aaed62-91c8-4865-bb0b-343e96691d73.pdf
SOURCE: ryobi plt 3043yw, wont start.
Hey www_mike350,
Just fixed my Ryobi 3043YW. I got this given to me not working and didnt even need it. I already have one. I decided to have a look over it, see if I could get it going.
To my surprise everything looked clean. I checked for spark, that was good, compression seemed good. I took the spark plug out and tipped some fuel in the cylinder, put the plug back in and tried to start it.
If it started I would have suspected the carby, but it still didnt start.
I was really annoyed because everything looked clean but it still wouldnt start. There was fuel, spark and compression, I didnt know what else could make this thing not start.
I pulled it completely apart and found the rotor assembly was the problem. It was causing a timing issue, meaning that it was sparking at the wrong times, when there was no gas in the cylinder.
On the inside of the rotor is a pin or a key that lines up on the shaft and gives the spark its timing. That key was made of cast iron and had broken off, causing the rotor to spin on the shaft out of alignment. This through the timing out.
I lined it up and tightened it and its working again. I couldnt believe it when it started, I have spent hours on this thing.
I will have to try and replace the rotor (Part no. 300952001), otherwise it will slip on the shaft again sooner or later and do the same thing.
Unfortunately I need to replace the gaskets too now as most came apart when I was pulling it apart.
Hope that helps someone out there!
