Question about Coleman Electronics - Others
Coleman lantern #5312 spiral bulb. problem: night light works ,battery fully charged. turn on hi knob; tube will flash momentarily then goes out, low setting will not come on. turn off and on several times and bulb may stay lit.. believe problem to be switch or blub generator. help!!! thanks
    Sergeant:
  • 200 Answers
Most times the problem with these is that the batteries, though they show fully charged, are in poor condition.
Test: Count the cells in this unit and multiply by 1.2 test for that voltage, 4.8 is common, at the batterypack and turn the light on, if the voltage falls below 1 volt per cell, the battery protection circuit will engage and turn the light off. This is a battery problem.
If the voltage stays relatively steady, the bulb is the second item to be a common failure. Shine a flashlight across the base of the bulb where the 2 ends enter the white base. It the tubes are pretty blackened, your bulb is likely bad.
I don't have the specs for that switch, but it's a pretty simple device, it connects power from the batterypack to the inverter board or to the nightlight. It's simple to test with either an ohm meter (power disconnected) Or a volt meter, (Power connected)
Posted on Feb 04, 2018
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 10 Answers
SOURCE: Coleman stove (Coleman fuel only).
Is it possible that the part that screws into the propane cylinder is not opening the bottle all the way. This would alow enough gas to flow through to light but will not keep a flame because there is just not enough fuel flow. If this is the case you most likely can't fix it and need a new one. How old is it, if you can return it for a new one, do that, just to be on the safe side.
Posted on Sep 24, 2008
Alan Grunewald
  • 6 Answers
SOURCE: Coleman rechargable lantern Model 5327A750.
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Posted on Aug 08, 2012
My lantern is not charging model 5312
Since the red led comes on it proves that the charger is working but since it is not able to charge the battery I would say that the battery is bad.
Nov 29, 2014 | Camping, Backpacking & Hiking
I have a coleman 5317 RC series lantern that wont go into the dim mode what can I do
Hello. I've just looked at several Coleman lamps, some have krypton bulbs (mainly battery powered), some spiral fluorescent bulbs (mainly mains powered/charged). If this one is yours http://www.coleman.com/Parts/100/parts-lanterns/5317-702/remote-control-pack-away-family-size-lantern# then it appears yours has a spiral fluorescent bulb. Gas discharge bulbs commonly are fired up by an initial high voltage pulse then followed by a continuous ac medium voltage (say 80 volts or so) to give a FIXED LIGHT OUTPUT.
THIS DOES NOT ALLOW CONTROLLED DIMMING. Dimming can usually only be done on an INCANDESCENT TYPE bulb eg an older type tungsten filament bulb. These are however much less efficient.
So in summary, if you do have a fluorescent bulb, I don't know why your remote indicates you can dim it. You could try switching the bulb for an incandescent type, but this should only be attempted by qualified persons. Check over the user manual again. Good Luck.
Jun 17, 2014 | Coleman 5317-700 lantern - 8d square...
Does not switch on after fully charging night light works if charger is plugged into power point
will the main light come on when plugged in? it might just need a new bulb. if so it might be a dead battery
Mar 11, 2014 | Coleman Retro Rechargeable Battery Powered...
Charge Time for 5312 Lantern Battery?
Charge time is 18hrs. If you left it on and it was flat, imediately charge for 40hrs.
heres the manual.
http://r1.coleman.com/Manuals/5312R.pdf
Feb 12, 2014 | Coleman Retro Rechargeable Battery Powered...
Manual for coleman lantern model 5348-700
simple unscrew the top clockwise and you will see how the tubes are removed,
Nov 22, 2011 | Camping, Backpacking & Hiking
Tried to charge my Coleman Retro Lantern, the red light for charging is on but after 24hrs charging, I take the charger off and try to turn the lantern on, it wont work. How can I fix this...
I just bought a retro rechargeable sealed battery,recently. I charged it for 18 hours,the lights all worked,but I don't remember the green light comming on.i put the lantern away for 3 months or so.i decided to check the the battery light out first week of june, the light was there,then I said let me charge it up again, I never seen any green light come on showing it was fully charged. I took the battery out and checked the wires to see if there was a break. None that I could tell. After you take the battery out ,there is another section square that covers where the bulb is located,but I didn't touch that part yet. Stuck" on this one. Help"
Sep 15, 2011 | Coleman Retro Rechargeable Battery Powered...
In the Coleman 5312 Retro Series Lamp is it supposed to work off the mains charger even if the battery will not charge. Battery is confirmed dead but lamp will not work on mains nor on 12v car lead. Don't...
Brentonb, In the event that you don't get a direct answer (which is likely, since this is a pretty obscure question) I suggest you troubleshoot it this way. Remove the bad battery. Use the charging device that came with the lantern and wire it temporarily to the device in place of the battery. This will supply the correct voltage, but takes the possibly shorted battery out of the circuit. If you are certain you have the polarity correct and you know that the charger works, then you have your answer. good luck.
Dec 03, 2010 | Coleman Retro Rechargeable Battery Powered...
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
Coleman rechargeable lantern: Charged overnight - not working, replaced bulbs - not working. What could it be:
Check the battery with a volt meter to make sure you have the correct voltage. If not, replace battery. If correct voltage, bypass switch to determine if it is good or not. If not, replace. There really isn't much to go wrong on the lanterns except the bulb or battery.
Jul 20, 2010 | Coleman Camping, Backpacking & Hiking
Electronics - Others Logo
1,086 people viewed this question
Top Coleman Electronics - Others Experts
Gil Shultz
ray gallant
ray gallant
txslim55
txslim55
Are you a Coleman Electronics - Other Expert? Answer questions, earn points and help others
