LG 42LC2D 42 in. LCD HDTV Logo
Posted on Sep 12, 2007
37LC7D I have had this one since June. Now the thing is having some problems. I can't get the remote to work most of the time. The buttons on the side do not fuction correctly either. Only the power button works correctly on the TV. You can not change channels or adjust the volume without pressing several combinations of the buttons in the side. The on-screen menu pops up frenquently by itself. Help!!!
A
Anonymous
What is the universal remote code for 37lc7d
  • Anonymous Aug 21, 2011
    ill buy it for the screen. call mark 706 322 4379 if you wanna get rid of it
1helpful
Standby Problem
its your lcd button problem open and clean it. then your problem will be solve there is a lot of dust in button.
On/off problems with my LG 37LC7D TV. It is hooked up to Direct TV
You need to contact a local TV repair service, UNLESS you have the tools and the repair manual to repair it yourself, it will take diagnostic work to determine what is the cause, one thing is for sure you have a defective circuit board.
3helpful
LG 37LC7D HDTV just went blank. Screen blacked out and green light is on but no response to input change, remote, volume, or channel change. I've unplugged it for several minutes in an effort to reboot...
My lg 37lc7d is having the same problem. My backlight is on but no display. Also the standby light blinks several times then the screen goes on but it's just all black. No a/v
Remote control doesn't work
You need to find out if the remote is puttimg out IR pulses or not using a digital camera, just point the remote at the camera lens, when you push any remote button, you should see flashing on the camera screen.
My LG 37LC7D is not working
The white/yellow/red cables is solely your DVD to TV cable connection, If you play a DVD do you get the DVD picture? It looks as if you do not have the connection from the cable going into your TV input (aerial connector). If this is connected then you have to retune your TV. this is done by the Menu-set up button on the remote.
37 inch LG LCD 720p
If everything else on the remote works, most likely the PWR function on the remote is not working.
This may be a problem with the conductive rubber membrane under the button, or the matracy circuit is not reading the function due to any number of problems.
You can call the manufacture parts rep to see if it is possible to have parts for the remote. Most of the time, they are not worth to service, and parts are not sold to support remote control service. You will most likely have to order a new remote from the manufacture rep.
I suggest to NOT buy a universal remote. They rarely can do more than the most basic functions. Many times universal remotes have different issues with different models of sets.
Jerry G.
6helpful
2answers
LG 37LC7D remote doesn't work
 I heard that Best Buy is still selling these models despite this known problem- I am trying to have mione fixed but was told the replacement part is on back order until DECEMBER!
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
