Swisher 44-Inch 12.5 HP Trailcutter #RTB12544 Logo
A
Anonymous Posted on Sep 05, 2013
44 inch rugged cut keeps breaking belts - Swisher 44-Inch 12.5 HP Trailcutter #RTB12544
How to replace Bottom belt on a 44 inch cut cub cadet
Type of equipment or model number. Also is this the lower DE k belt.
I have a great dane brutus 61 inch cut it keeps kicking the belt off
More than likely you have a bent pulley or pulley guide, the only other thing to try is a slightly longer belt.
Jan 06, 2015 • Garden
Change belt
Changing the belt on the swisher 44' rough cut - mine is a model RTB134412v. You have to remove the belt guard (4 bolts) and then the 6 bolts holding the engine on to the deck. Lift (or tilt) the engine up and loop the 1/2"x50" belt (I got a husky replacement belt at tractor supply) through the wire belt guides and around the engine belt drive. Then loop the belt around the larger blade drive. It takes about 30 mins or so. Hope that helps.
The belt on the cutting deck on my NZT, 52 inch mower deck keeps breaking.
The belt may not be that good of quality. Or you have it to tight. Next time it break I would recommend spending a couple extra buck on an industrial grade belt.
Dec 30, 2012 • Garden
2answers
Belt keeps breaking after only short use on vacum cleaner
Each vacuum cleaner manufacturer produces specific belts for specific machines. An incompatible belt installed on the vacuum cleaner will cause the belt to break or burn. The belt must be installed according to manufacturer directions for best performance, or the belt will chafe against the interior housing parts and break prematurely.Sharp debris, a low height adjustment setting or vacuuming up rug corners may cause the rubber belt to snap or wear prematurely. Check the height adjustment for the vacuum, and use a higher setting for plush rugs. Avoid vacuuming sharp objects and corners of the rug.
Jul 27, 2011 • Vacuums
The belts keep busting. i check the roller brush and it moves easily with out the belt. why do the belts keep busting?
1) could be the belts you are using are not for that particular model.
2) depending on what you are vacuuming, a rug on the floor for example with tassels will always break the belt when it gets caught into the roller brush.
9helpful
What size belt fits swisher 44 inch cut mod. no.t 11544
Our manual says 74" part no. 4220. We just replaced one but can't figure out how to adjust the tension.
My washer will not drain . I washed bathroom rugs that fell apart leaving excess fibers that I beleive plugged up the holes that allows drainage. A few gallons of water is still sitting in my washer and...
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Top Swisher Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Swisher Garden Expert? Answer questions, earn points and help others
