Inverter KEB COMBIVERT F5 Logo
A
Anonymous Posted on Sep 02, 2013
Fault Puci1 - Inverter KEB COMBIVERT F5
mntech1
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
New Friend:
  • Inverter Expert 120 Answers
  • Posted on Jul 10, 2014
mntech1
Inverter Expert
Level 2:
Mentor:
New Friend:
Answers
120
Questions
0
Helped
78072
Points
185
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
2answers
MY YBR ENGINE MANAGEMENT LIGHT FLASHES 3 SHORT FOLLOWED BY 3 FAST
That indicates fault code 33 which is a faulty ignition coil
Fault code 12 - Crankshaft position sensor
Fault code 13 - Intake air pressure sensor
Fault code 14 - Intake air pressure sensor
Fault code 15 - Throttle position sensor
Fault code 16 - TPS
Fault code 19 - No signal from ignition to ecu
Fault code 22 - Intake air temp sensor
Fault code 28 - Engine temp sensor
Fault code 30 - Tip over sensor
Fault code 33 - Igniton coil
Fault code 39 - Fuel injector
Fault code 41 - Tip over sensor
Fault code 44 - Read write error ECU
Fault code 46 - Power supply error to FI system
Fault code 50 - Ecu malfunction
What does error codes 40 and 41 mean on my 1999 mitsubishi eclispe mean
11 Oxygen sensor fault.
12 Airflow sensor fault.
13 Intake air temp sensor fault.
14 Throttle position sensor (TPS) fault.
15 Idle speed control (ISC) motor position sensor fault.
21 Coolant temp sensor fault.
22 Crankshaft position (CKP) sesnor fault.
23 Camshaft position (CMP) sensor fault.
24 Vehicle speed sensor (VSS) fault.
25 Barometric (BARO) pressure sensor fault.
31 Knock sensor fault.
32 MAP sensor faulty.
36 Ignition timing adjustment signal fault.
39 Oxygen (O2) sensor fault.
41 Injector(s) fault
42 Fuel pump fault.
43 EGR fault.
44 Ignition coil (cylinders #1 & #4) fault.
52 Ignition coil (cylinders #2 & #5) fault.
53 Ignition coil (cylinders #3 & #6) fault.
55 Idle air control (IAC) valve position sensor fault.
59 Rear Oxygen (O2) sesnor fault.
61 Transaxle control module torque reduction signal fault.
62 Variable Induction control (VIC) valve position sensor fault.
71 Traction control (TC) vacuum valve solenoid fault.
72 Traction Control (TC) vent valve solenoid fault.
Fault signal lamp of automobile engine always light,what is matter?my car brand is toyota
The key to read the related information of fault codes and the fault code occurs when the car diagnostic tool records through the diagnostic instrument (usually contain frequency, fault fault, fault speed, speed, temperature, air pressure, the number of kilometers and so on), analysis of the causes of failure by these information. Some fault code does not cause the engine sound changes, such as the vehicle speed sensor fault, oxygen sensor failure etc.. You say are associated with oil or air filter fault may be fuel too thin / thick oil gas path fault, maintenance of this case can be resolved.
2answers
41 thrt val sol
P0041 Oxygen Sensor Signals Swapped Bank 1 Sensor 2/Bank 2 Sensor 2
looks like your wires and melted together or a rodent has chewed them
2answers
I have a 2002 Jaguar X-type. The check engine light came on and it has been acting jumpy/shaky. I recently took it to be diagnosed and the codes I recieved back were P1314, P1316, P1111, and P0302..What do...
All fault codes can be checked out at http://www.bluejag.co.uk but here are the results for some of yours. You can ignor P1111. Looks like a faulty plug or coil pack cylinder 2
Fault Code:- P1314 Indicates a Power-train fault
The fault is generally due to a problem in the Ignition or Misfire area
Fault Description: Misfire rate catalyst damage -bank 2 NOTE: This DTC will flag only when accompanied by an individual cylinder misfire DTC: P0300 - P0306
Action of ECM:- ECM Default:- Maximum engine speed reduced
After clearing the DTC, complete the Misfire monitor drive cycle
Check for a reoccurrence of fault DTC.
Possible Fault:- Cylinder compression low Worn camshaft / broken valve spring(s) Fuel delivery pressure (low / high) Fuel injector(s) restricted / leaking Fuel injector(s) continuously open Fuel contamination Fuel injector circuit fault(s) (Injector DTCs also flagged) Spark plug failure / fouled / incorrect gap ECM to ignition coil primary circuit fault (Cylinder misfire detected DTC also flagged) Ignition coil failure
Fault Code:- P1316 Indicates a Power-train fault
Fault Description: Misfire excess emission NOTE: This DTC will flag only when accompanied by an individual cylinder misfire DTC: P0300 - P0306
Action of ECM:- none
Fault Code:-
P0302 Indicates a Power-train fault
Fault Description: Misfire detected ?€" cylinder 2
Possible Fault:- Refer to P0300 Possible Causes
1helpful
2answers
Check abs system lite on how do you find the code list
ABS Fault Code List 1991 Corvette (C4)
Code Definition
21 Right Front Wheel Speed Sensor Fault
22 Right Front Toothed Wheel Frequency Error
25 Left Front Wheel Speed Sensor Fault
26 Left Front Toothed Wheel Frequency Error
31 Right Rear Wheel Speed Sensor Fault
32 Right Rear Toothed Wheel Frequency Error
35 Left Rear Wheel Speed Sensor Fault
36 Left Rear Toothed Wheel Frequency Error
41 Right Front Solenoid Valve Fault
45 Left Front Solenoid Valve Fault
55 Rear Wheels Solenoid Valve Fault
61 Pump Motor or Motor Relay Fault
63 Solenoid Valve Relay Fault
71 Electronic Brake Control Module Fault
72 Serial Data Line Fault
75 Lateral Accelerometer Fault (Short ot Open)
76 Lateral Accelerometer Fault (Signal out of Range)
7helpful
Trouble Codes
1. VW VAG type 5 digit fault code 19497 = EOBD type P3041 fault code:
Fault location = CAN data bus, instrumentation - implausible Engine Coolant Temperature (ECT) signal
Probable cause = Wiring, matching resistor in Engine Control Module (ECM)
2. VW VAG type 5 digit fault code 18032 = EOBD type P1624 fault code:
Fault location = Malfunction Indicator Lamp (MIL) - request signal active
Probable cause = Trouble code(s) stored in other system(s)
3. VW VAG type 5 digit fault code 01039:
Fault location = Coolant Temperature Sensor (G2)
Probable cause = Open or Short to Plus, Short to Ground - Intermittent
4. VW VAG type 5 digit fault code 01304:
Fault location = Radio
Probable cause = No Communication
5. EOBD type P0761 fault code:
Fault location = Shift Solenoid C
Probable cause = Performance or Stuck OFF
7helpful
APC BR1500LCD Fault F01
This is a printout of the fault codes
System Fault indicator is on and all other
front panel indicators are flashing.
Internal UPS fault. One of nine Internal UPS Fault Messages is displayed:
F01 - On-Battery Overload F06 - Relay Welding
F02 - On-Battery Output Short F07 - Temperature
F03 - On-Battery XCap Overload F08 - Fan Fault
F04 - Clamp Short F09 - Internal Fault
F05 - Charger Fault
6helpful
Start light flashing wont start cycle, what does it mean
count the number of flashes- this indicates fault ie will flash 4 times stop, flash 4 times stop. To clear fault, hold start button for 3 secs. Try running another fast cycle- if fault reoccurs count flashes: Number of flashes:1=NTC fault, 2=Flood switch activated, 3=Heating fault, 4=drain fault, 6=water inlet fault, 7=flow meter fault, 8=water level fault
Top Inverter Electronics - Others Experts
Ngoro
john h
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
