How to put a new pull rope on it
How do I put a new pull rope on
It realy depends on what model we are talking about, so i will give a general disciption, remove the four screws retaining the starter to the saw, remove the starter, if the cord is still under tention, pull the starter handle out approx 8", whilst held out hold the pulley to stop it retracting, let go the starter handle and unwind the now lose cord from around the pulley, once enough cord has been unwound let the pulley slowly turn until all the spring tention has gone, remove the center fixing screw, and remove the pulley, pull the old cord away, refit a new suitable diameter cord, knot the end and pull the cord into the pulley so as the knot sits flush into the hole in the pulley, wind the cord fully around the pulley,now refit the pulley to the cover, refit the centre screw ,push the other end of the cord through the cover eyelet and refit the starter handle with a suitable knot, now wind the cord around the pulley a further two times by turning the pulley and winding up the spring, allow the spring to pull the cord in, if required wind the pulley a further turn until the cord is suitably tentioned in the cover, replace the cover on the machine, pull the cord out to make sure it has engaged fully into the pawls before fully tightening the fixing screws.
