Assuming you are referring to the Coleman Campers Grill Stove which is a side by side grill and stove unit than it is a pretty simple set up. All portable Coleman stoves set up basically the same. There should be a arm known as a regulator that came with the stove. The narrow end of this attaches to the right side of the stove and screws in. Then the propane bottle screws into the other larger end. make sure all connections are screwed together tightly. For more clarification check out these instructions: http://www.ehow.com/how_2106008_use-coleman-stove.html https://www.youtube.com/watch?v=dbYil-YQ8-Y
Yes. There are multiple adapters made to fit this application. Your local walmart most likely will have them.
http://www.walmart.com/ip/Coleman-5-High-Pressure-Propane-Hose-and-Adapter/19897422
You could try Coleman directly if there is no repair depot near where you live.
The Coleman Company, Inc.
3600 North Hydraulic
Wichita, KS 67219
1-800-835-3278
Is there a reason or a need? I cannot imagine why you would want to, except as a point of interest for your camp kitchen. A new propane stove would work better and not cost all that much, relative to the work and cost of putting fittings, pipes and burners into the old stove box.
Ozark Trail GCT1705W Portable 2-Burner Double Propane Gas Stove replacement parts ARE NOT AVALABLE ANYWHERE !the only thing you can do is get a coleman regulator part number 5430 regulator .cut you tube and hose clamp it to the new one ! use a 5/16 fuel line use 4 clamps on each sides ! these stoves are junk and we are bot stuck with them :( this way beats throwing the piece of junk out ,then you will have a usable stove with a coleman regulator
the fuel to air mixture is set incorrectlty or your pressure at the ouitlet for the gas valve is too low.
you culd play around adjusting the first part of this but for the gas valve part you have to have a manaometer to check it out correctly. then it should be set at 10"wc. Good Luck
