The dispenser on my refrigerator will not stop dispensing water. The tab appears to be stuck. So I pressed the button that locks the dispenser in order to stop the flow, but whenever I unlock it the flow continues. What should I do?
This worked out perfectly!! Thanks!!
We just had this problem and we fixed it by peeling off the soft rubber covering (the part you press the glass against)and then putting it back on. There is a plastic tab beneath that could get stuck if the rubber part gets an air pocket or bent out of shape. This took 2 minutes and worked like a charm.
ours is a frigidaire & the dispenser will not stop spitting out the ice
Had the same problem and peeled the rubber gasket off to pull off the dispenser trigger. My problem is how do I reattach the rubber gasket?
If I unplug and replug the switch, the water starts dispensing, the freezer shows -17C, the fridge shows 2C, water continues to dispense and then suddenly stops and the freezer temperature screen starts showing Err.
Bought a used refrigerator. Hooked up water line, but no ice and no water flowing. No sound when dispenser buttons pushed either. Aunt advice appreciated
pushed lock feature and now it will not unlock... no water dispensed or changes allowed.
The plate that you push in to dispense ice sticks in and ice continues to flow.
You have to reach in and pull dispenser out to stop the flow of ice.
you have to reach in and pull it out to stop ice from dispensing
