You have need printer support services. We provide the ALL Types of printer services as Hp, Epson, Canon, Brothers, And Samsung. You can any time visit here https://printwithus.us/ and chat with our Expert team today!
I have the exact same issue with my Canon Pixma MG3650 Series, It will not print a straight line at all its doing zig-zags all the way down the paper it's crazy I recommend you print this picture below to make sure that your printer is not faulty
If it prints it Wonky or anything I recommend you open your cartridge tray & use a tissue to wipe off excess ink.
SOURCE: mutiple lines on right side of photo
try removing the ink cartrage and clean the heads in the printer with a quetip and rubbing alcohol. same with the cartrages.
SOURCE: canon pixma mx 300 won't send or receive fax
how do u fix the fax to fax and not go on auto redial
SOURCE: colors print blurred
you need to run the nozzle deep cleaning utility, nozzle check and alignment procedure under the printer properties maintenance tab.
Please rate this solution. Thanks.
SOURCE: i have canon405 machin these are give zig zag line
Do you mean that you have paper that are wrinkled in zig-zag?
If yes, then you have three possible problems:
1) moisture on paper - in cass flip paper, upside down, and then see, if its ok change paper.
2) bad pressure between pressure and fixing roller
3) worn out pressure roller
SOURCE: canon pixma mx 320 error 5800
there are two ways you can remove the error message from your printer..
the
first is to reset the printer and the second is to replace the waste ink
absorber. If the reset thing did not work for your then you'll be
spending money to replace the absorber.
How to reset? follow these steps
1. Turn off your printer
2. Press and hold the
STOP/RESET button
3. Press and hold Power ON button
4. While
holding the Power ON button, release the STOP/RESET button
5. While
holding still the Power ON button, press twice the STOP/RESET button
6.
Release the Power ON button
7. Wait until it display an "idle"
message. It will take about a minute.
8. When "idle" appear, open
the top cover to expose the cartridges.
9. Lift up the cover for
cartridge holder and take out both the black and color cartridges
10.
Return the cover of cartridge holder and turn off the printer
11.
Return the top cover and turn on the printer again
12. After the
printer initialize, return the cartridges.
Hope that solve the waste ink absorber in your printer..
