SOURCE: Scotsman CM250AE Ice Machine tech help
Check the bridge size adjustment at the top of the metal grid that the ice forms on. This determines the size of the cubes. Whenever you make a repair on the water system, especially on an older unit. make sure the unit is clean. A little bit of calcium deposits (or that other nasty looking stuff) getting into the passage ways will make it run erratically, and can drive you nuts.
SOURCE: CME500 ICEMACHINE MAKES ON BOTTOM PART OF CUBER ONLY
Hi!!!Relax you just answer your question.If you went and advance the timer and it work but was stuck in the same position well its your bad timer.change timer and you will be fine..Good luck
SOURCE: ice sheets too thick to shatter when dropped
timer not working properly replace if necessary
SOURCE: hi.my scotsman mv 450 ice machine harvest cycle is
hi i have mv 1000 scotsman my problim is very early in harvest if i pull ice sensor connector in the mudule the unit is making ice after 20 min i put again the ice sensor in the module so that i can harvest the ice.
somebody could help me this problim?
Questions
1.is my ice sensor basted?
2.there is wrong with my module?
3.can i adjust in the trimer?
SOURCE: why does my scotsman ice machine, model
check ice thickness thermistor if its not working properly timer will never start advancing
