SOURCE: CHECK ENGINE LIGHT ON AND REDUCED POWER LIGHT ON,
Replace your throttle position sensor, runs about $60.00 sit on throttle body has a round connector with three wires going o it.
SOURCE: cadillac cts cranks but won't start
My 2003 CTS would not start on the first, second or third try after filling the gas tank. Finally after several months of this occuring every two weeks a check engine light came on. It was the evac purge valve. Tom
SOURCE: Need to add transmission fluid in Cadillac CTS
tod34 is correct. The "fill" area of this transmission is located on the transmission itself. It is a fluid leveling plug located low on the main case toward the back of the trans. You must pump the fluid in through that hole. If you are on level ground and the transmission is properly warmed, you should fill the transmission until the fluid level is flush with the bottom of the hole (starts spilling out)
