SanDisk Sansa E280 MP3 Player Logo
Posted on Mar 26, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ear phones Jack not working properly
My earphone jack use to work with my player. But the other day I put it in and it either played only the left side or only the right, or it would jump back and forth and be unclear. The only way it will work is if i press it down with my finger really hard. But I can't do that when my hands are not free. Sometimes I can turn the jack a certain way and it might be clear in both ears. I tried using other headphones and I still had the same problem. Is there something maybe down in the hole of the jack? If so what is the best way to get it out. I am upset because I just got this player a few months ago. And my jack is the standard size, because it worked before. I am very angry about this, and would appreciate your help.
  • wiseowl77 Apr 22, 2009
    Only the left side of the earjack works.
    I also tried it on my home speakers and the same thing,only one side works.
    Where can one get this repaired??
    [email protected]
Grubhead
Level 3:
  • SanDisk Master 5,755 Answers
  • Posted on Mar 26, 2017
 Grubhead
SanDisk Master
Level 3:
Answers
5755
Questions
Helped
1662618
Points
11417
It's possible that there is bad soldering to the jack's contacts.
5 Related Answers
Anonymous
  • 23 Answers
  • Posted on Jun 06, 2007
SOURCE: Earphone jack has a short.
take it apart resolder the connections. if the jack itself is bad see if you can find a new one. never worked on something that small myself, but should be fairly straighforward
Anonymous
  • Posted on Sep 13, 2007
SOURCE: headphone jack
I had the same problem on my e200 series after maybe 8 months of use. If you apply some pressure from the side of the plug, the sound should come back. Wiggle it even. If this is the case, there is a connection problem. If under a year old, RMA it with the company, I just got mine back from the same issue. I have also read that if not under warrenty, you can take aprt the player and apply a shim (piece of cardboard the thinkness of a matchbook cover) inside to fix. There are other posting on the web that describe this in detail from people who claim to have done this sucessfully. Cheers
A
Anonymous
  • Posted on Oct 28, 2007
SOURCE: Self Panning Headphones
Change the equalizer when this occurs. It works for me.
Anonymous
  • 322 Answers
  • Posted on May 03, 2009
SOURCE: sound only in right ear
Its either the jack or the connector in the device is the problem. You can try connecting other headphone, if this works, then the problem lies on the jack of the old headphone.
Anonymous
  • 52 Answers
  • Posted on Jul 02, 2009
SOURCE: the headphone connection is not working. the sound
check head phones
What can I do about my ear phone jack not working?
Earphone jack ... for changing a tire? Earphone jack on WHAT?
2answers
Headphone/earphones only left ear plays
Either the plus is not completely inserted (most likely) or a wire is loose or the earphones are damaged.
No matter what set of head phones i plug into to my lyra rca mp3 player the left ear phone won't play anything
Most of this symptoms is a caused by bad solder joints on the earphone jack of the player. The unit must be take apart and re-solder the joints of the earphone jack. You need a pointed soldering iron to do this. If the symptoms still persist, the fault is in the audio circuitry. You must sent it in because this is not DIY, parts are too small and surface mounted.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
2answers
Apple Ipod 4th Generation is only playing music through left ear jack. I'm confident it is a earphone/jack replacement issue. The problem occured when someone yanked my ipod from me and the ear bud cord...
Well, yes you are right there is no other issue than earphone. you can purchase the earphone from the below link -
http://cgi.ebay.com/ORIGINAL-Apple-4Gen-Earphones-Headphones-for-All-iPod_W0QQitemZ260523098037QQcmdZViewItemQQimsxZ20091214?IMSfp=TL091214234010r19836
Good Luck!!
Thanks
Sound from 1 side only!
your ear input female jack is stripped try another new pair of earphones if not you may have to take it in for service.
1helpful
Doesnt sounds right...
Try a diffrent pair of earphones if that does not work the jack is shorted on the media player and needs to be serviced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Headphone Malfunction
It's probably the jack inside mp3 player who needs a little bit of solde on his contact.
open it and good luck
2 sets of headphones will play only on left earphone.
Dirt inside of the headphone jack can be the culprit. If you have canned air, you can blow it out, or twist the headphone connector inside the jack to clean the contacts.
Ear plug
That is normal for most mp3 players
If you are getting sound out of only one ear, then the headphone jack is broke - unfortunately, Philips does not have any more HDD models to send you as a replacement
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
