I am in need of codes to program my remote for use with a Sony t.v.
The codes to Sony TV's Are:
0414
0902
0801
0708
0639
Good Luck
This is for model number 3L034
I PERSONALLY JUST USED THIS METHOD!!!
Here is the CORRECT way of programing...
1) Manually turn on the device (TV, DVD) to be controlled.
2) Press and hold code search button until the red indicator stays on. Release the code search button.
3) Press and release the desired mode button (TV, DVD,etc)
4) Press the Channel Up button repeatedly (up to 300 times) until the device to be controlled changes channel.
5) Press and release the OK button to install the code
I have the same remote and couldn't find the manual. I found it online. Here you go! :)
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
hope this relieves your frustration as it did mine. enjoy!
b.
Hello People,
I have the original Owner's Manual for that remote. The inside battery pack has a sticker that says "CL034". Which, without having anything else written or stamped on the unit, would leave a reasonably intelligent person to believe that it is some sort of identification number. Wrong, The morons at Philips cost me 3 hrs of my life because they decided this remote model number is "PMDVR8 / PDVR8". Then neglected to mark it somewhere on the device. Why?..... Lazy? Cheap? Incompetant? You decide!
I finally found the orginal. Look up that number, you'll have better luck.
Well this link helped me solve my problems for my CL034
I hope it helps you solve your problem with your CL034
have fun with it, huggers
Lisa
The mute really worked!
just dont press up and extra time, as soon as it changes stop and use the mute
thank you!
I need codes for CL034 for tv magnavox
Dont let audrina help u
It all works!!:)
Hey the mute button thing worked. Make sure you read all his steps, but it worked with my orion TV.
Thanks!
Here is an alternate way of programing... 1) Manually turn on the device (TV, DVD) to be controlled. 2) Press and hold code search button until the red indicator stays on. Release the code search button. 3) Press and release the desired mode button (TV, DVD,etc) 4) Press the Channel Up button repeatedly (up to 300 times) until the device to be controlled changes channel. 5) Press and release the Mute button to install the code.
SOURCE: Philips Magnanox Universal Remote CL034
I found this website and it has the codes for everything for your universal remote. Good Luck.
http://www.universal-remote.net/philipsmagnavox.html
SOURCE: I have a phillips CL034 universal remote need code for sharp tv
this should work:
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
SOURCE: philips universal remote control cl034
Try this website it really works. I just tried it today and I am sooo happy.
Orion TV code?
remote CL034 code for apex tv
I need the codes that go with the philips universal remote cl034 for a sharp television
cl034
i need all codes for my philips universal remote model cl034
phillips cl034 control
i need code for CLO34 remote
I just bought a used Sony TV that came with a Philips universal remote and I must have hit the wrong button because the remote will not work on the tv now. I've tried using the code search but cannot seem to find the right 3 digit code.
i need the code for a philips magnavox tv
Needs code to program my Phillips Universal remote control.
MGA "19" TV Sony VCR Sony DVD
need codes to program my remote control
I need codes for cl034 as well, any help is appreciated.
[email protected]
I need the codes for the philips univrsal remote #cl034
codes for daewoo t.v.?
I need the codes for cl034 Philips universal remote
me 2
nice!....worked for me...not the first time....was hitting channel up to fast....go slow....thx
I need the codes for an RCA tv.
I 'M HAVINGTHE SAME PROBLEM WITH MY REDMOTE. WHEN I CHANGED THE BATTERIES, THE REMOTE CONROL STOP WORKING. I DID FLOLLOW THE ABOVE DIRECTION, IT ALL WORKED, UNTIL, IT SAY TO PRESS THE MUTE BUTTON, WHN I DID THAT, IT WOULD NOT DO ANYTHING. I REPEATED IT OVER AND OVER, BUT THAT'S AS FAR IT WOULD GO.HELP PLEASE.
I used the same solution listed below. The codes are not working for me yet. I know Im programming them right so now I gotta change the batteries. The only thing Im having problems with is trying to program it by brand, mine is the number "5" for JVC. I've tried 0005, just plain 5 and just 0. I have ditched trying that one in favor of the "all search" but the possibility of pushing the button 300 plus times doesnt sound fun. I
wish it had a picture so I can see if it looks like mine. I found the CL034 in the battery compartment labeled on the side of the compartment so Im sure that I have the right model number but want to further comfirm.
thanks, Lisa
I have the solution. If you press "code search"then "TV",then get comfy and press the channel button up unitl the tv changes channel (if you are going too fast you CAN press "channel down"unitl you get back to that frequency), and then press press the öK"button in the middle of the remote, it will work..
Thanks man it worked !!!! Coll bean your awesome
i need the code for my samsung dvd player P231, i have a philips universal remote control CL034
programming philips universal remote to a sony tv
