My Samsung washing machine keeps going out on the error '4E'. The troubleshooting guide tells me to check both water pressure and clean in-line filters.
I have checked all lines, filters and solenoids and everything works fine, it fills up on pre-wash no problems and then trips out after a few minutes on '4E'.
If you have pulled out and cleaned the filter at the back of the machine where the hose connects then I would check that your pump is not running during the cycle and also make sure your drain line is at least half way above your drum at its highest point, If its too low then it will drain off even if the pump is not running.
Try swapping the plugs over on the water inlet valves. If it runs properly once doing this, you know that one of the valves is faulty. This is a cheap part and easy to replace.
it doesnt fill up or drain just doesnt do any thing wen set to run its program?????????????
water pressure is right filters are clean evry thing is clean and set and after a few minutes it displays 4E
