how old is your trail mower? have you checked the pulleys for the belt drive? possibly the pulleys are loose, or the shafts holding them are worn and wobbling causing a misalignment of the belt, in turn shredding the belt. also check the pulleys to make sure they are smooth, allowing the belt to move cleanly
The engine in this machine seems to be powerful. If you can remove the belt from the pulley that drives the blade. Try turning the pulley buy hand. If it turns tight or not at all this is your problem. The unit that is the pulley to blade assembly is seized or ready to seize. Sometimes they are designed to be taken apart and repaired, and sometimes they are not. Did you check for a grease fitting within the pulley to blade unit? I would like to hear how this works out for you. Best of luck.
