SOURCE: I have a JVC HD52z575 that when I turn it on the
Power supply would be the issue the fix would be my good friends @ www.teexp.com I hope this helps.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: JVC HD-52G787 52-Inch HDILA Rear Projection won't turn on
My tv wont turn on. It tries to turn on the green light lights up 3 times then nothing. what is wrong?
SOURCE: I have a JVC AV-56Wp74 Blue power light on the
There are a couple of common problems this model has--one is easy to confirm.
How handy are you if I tell you to disconnect the convergence board to see if it is your problem?
The blinking blue light means the set is in protective shutdown, and I know a fairly easy way to see if it is your problem and how to fix the set if it is.
Let me know if you need help--I am here to help people and l know a lot about this set.
SD TECH
Testimonial: "this was very helpful thanks"
