Question about Maytag Neptune MAH7500WH Front Load Washer
Can you change the way the door opens on the neptune washer
Sorry wrong model # can you change the door to open from left to right, at present the door opens right to left.
Got an answer ...thank you
Posted on Apr 11, 2009
Anonymous
SOURCE:
Does LG Model WM2301H come in model with door opening left to right instead of right to left
Sorry - there is no retro-fit adapter that will allow you to change the swing.
Thanks for using FixYa - a 4 THUMB rating is appreciated for answering your FREE question.
Jul 19, 2010 | LG WD-1080FD Front Load Washer
Can I change the side the door opens?
Unfortunately you cannot reverse the doors on this model. There have only been two front load washers that I know of that had reversible doors, the maytag neptune and amana front loaders. Your matching dryer for this model, I believe has a reversible door, but you'll have to purchase a kit to do it. IF needed maybe you can switch the dryer and washer locations to make them more accessible?
Sorry, and good luck to you!
Jul 03, 2010 | Whirlpool GHW9100L Front Load Washer
Maytag Neptune door lock stuck!!!
Try these steps:
1.) Take the washer outside. 2.) Loosen the two screws on the back panel and remove the back panel. The pump sits on the left-side of the opening. There's a black water hose with a metal clamp; 3.) squeeze the metal clamp with your fingers until it's loose enough to slide away from the pump. 4.) Separate the hose from pump and the trapped water will pour out and the door will then open; and 5.) clear any blockage from the drain hose and the pump.
Jul 01, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Yes you can reverse the door on your washer.
Open the door, remove the screw in the middle of both hinges, (carefull not to drop them inside). Lift the door straight up and "wiggle" the door hinge straight out of the slot.
On the opposite side of the opening you will find two inserts, remove them and install them into the slots you removed the door from. Now the fun part... remove the hinges from your door side.
Make sure you note how they attach, now intall them on the other side of the door,EXACTLY, the way they were first installed. Do one at at time. After you have them on the other side and you put the other screws back in the side you removed the hinge from, lift the door and slide the hinge into the bottom and top slots of the washer opening. Secure the hinge with screws removed in the beginning making sure the door is closing properly and locking.
Apr 10, 2009 | Maytag Neptune MAH6500A Front Load Washer
Maytag neptune dryer making load noise seems unbalanced
Sounds more like the dryer drum seal is deteriorating.
If the dryer tumbles the belt is intact.
To access the belt.
Open the door.
Remove 4 screws on right and left side of the door opening.
Raise the door on the hinge side and remove it.
Pull the front panel forward and remove it.
From there you can see what to do next.
Mar 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Can you switch the side the doors open and close.
sorry but the washer can not be changed. its strike has a lock and can not be reversed. the dryer can be changed, but the best thing to do is move the units and get some longer hoses for the washer.
hopefully you can switch the position of the units, but if not then you will be doing the laundry dance every time you do wash.
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer door opens with hinges on the left
nope sorry but all front load washers are built with a locking system on the door and that makes them impossible to change the door swing.
the only thing you can do is move the washer and dryer position by getting longer hoses and venting so you can have the washer on the left and the dryer on the right.
Dec 28, 2008 | LG Washing Machines
Neptune washer not starting
open panel at rear of control panel usning phillips head and 5/16 the board attached to that panel will probably have a burnt r14 r1 or r21 resistor. this has been an ongoing problem with this model even a class action lawsuit.(lawsuit expired 9/2005) you can change the board but this will eventually happen again maytag directs you to do a full conversion kit rebuild about $400.
Feb 17, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune model MAH5500BB
yes you can take off the bottom panel and reach up on the right side toward the door lock there is a plastic like a string there pull it and will unlock door but i need you to email at b4829@yahoo.com with your complete model and serial # may have important info for you
Dec 30, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH7500WH Front Load Washer Logo
105 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
