SOURCE: Reattach mower deck spring instruction
I have a 13.5 Yardman, MTD I can figure out how to reattach the deck springs? please help.
SOURCE: My MTD Yardman HE4160 just stopped yesterday
You can start by getting a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
The above web site also has a "parts finder" that gives detailed drawings for each model.
If you look around under the mower, you should be able to find the hole, or bracket where the spring was hooked. (look for rub marks, or scratches)
If the spring just fell off for no apparent reason, it may have been connected to a bracket that broke off (rust, vibration, etc) It is usually easier to make a new bracket then to try finding a replacement.
SOURCE: 609 yard machine tractor idler pulley spring broke
Here's a diagram, not a great copy, but it may help:
The spring hooks to the idler arm on the opposite end from where the pulley is mounted. The other end of the spring looks like it hooks to a raised tab on the deck, straight behind the left mower spindle. Hope this helps you, please rate my solution if so, thanks!
