When I switch onthe system systrem I get te message the system Shows the error " Chasis Intruded Fatal Error System halted "
Resetted the Bios and even tried the Load setup defaults
but still the problem persists
please provide a solution . Is it with the BIOS or the Processor / Motherboard
Try to remove the cmos battery and load it again.. before system boot press delete to run in bios choose advance default setting.. dont forget to check back the time and date setting...
or try this Go onto your Mobo and disconnect the connector that usually says something like CHA_DET. Look in your manual for the plug. That should solve your problem. If not, check to make sure everything on your case is screwed on so that the Detector's circuit is complete. A separated piece, like a loose panel might be causing the problem
If you purchased this motherboard recently then i would double check your power supply - get a better power supply and try that - think you may need one with two 12 volt rails.
If that does not work then I would get it RMA'd as in return it and get a replacement.
