Question about Kenmore HE2 Plus Front Load Washer
Just bought this model and am having some water leakage from the bottom. It doesn't seem to be sealing right.
  • 15,935 Answers
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Anonymous
SOURCE:
Water leakage
COOLANT (COLORED?) CHECK THE FOLLOWING:
1. ALL RADIATOR AND HEATER HOSES FOR LEAKS OR LOOSE CLAMPS
2. LOOK FOR A CRACKED OVERFLOW BOTTLE
3. MODERN WATER PUMPS CONTAIN A "BOTTOM SIDE" SMALL WEEP HOLE THAT WILL START LEAKING WHEN THE SEAL AND BEARING ARE FAILING
4. ALSO CHECK RAD CAP, RADIATOR SIDES AND BOTTOM TANKS FOR LEAKAGE, AND WEEPING AROUND THERMOSTAT COVER
Dec 20, 2013 | 2004 Mustang Factory Wiring Diagrams
Kohler santa rosa fills, shuts off, a little water leaks from tank, toilet refills and repeats the leakage into the drain.
There is a rubber seal at the bottom of the flush valve that covers the openning at the bottom of the tank. If this rubber seal has perished slightly then it will leak water into the toilet bowl. This rubber seal need to be replaced to form a proper seal to prevent water leak.
Dec 27, 2011 | Kohler - Toilet - One-piece - Santa Rosa -...
Leaking water on the right hand side
Does it seem to be coming from the door it self or from underneath the unit?
If it's coming from the door, check the seal or maybe replace it. It's easy enough and cheap.
(disconnect power before proceeding to the next step)
If it's coming from underneath the unit, first start a cycle to drain it then stop it. Pull the unit out and flip it to its side(have a couple towels ready), then remove the bottom cover and check hoses connects or any signs of leakage.
Feb 23, 2011 | LG 24 in. LDF7810 Built-in Dishwasher
I have a Whirlpool Gold GU3600XTSY0 Model. There is slow water leak from the right side bottom front of the dishwasher. It looks like the water is leaking from a sensor on the bottom. The sensor has a...
I would look at the door seal being a problem as well. if the water level float were leaking, it would be worse then just a little water. The door seal is always the first to go. these seal can be replaced by pulling the old one off and pushing the new one back in place. should be able to buy new seal from the people the unit can be bought from.
Dec 19, 2010 | Dishwashers
I have a Neff built-in dishwasher and sometimes there is a heavy leakage of water from the front right-hand side. The unit is 3-years old and there is a build up of scale around the rubber seals. The long...
Check the rubber seal in the bottom of the door has not perished or split,also check the bottom spray arm has not split on the ends as this will direct the spray directly onto the door,causing it to leak.
Hope this helps
Sep 19, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
Lately when i run my dishwasher, it leaks from the front but i can't seem to pinpoint where the leak is coming from
If the water is not overflowing the bottom due to a bad float/switch, check the perimeter door seals for any damage. There is usually no seal at the bottom of the door. Check around the pump and associated hoses for any signs of leakage. Make sure that the latch is holding the door tightly while operating.
Jan 30, 2010 | Dishwashers
Bosch SHU4302 DW has a leak in the bottom left. I cleaned the gasket etc. but no luck. Slow leak drip by drip in the wash cycle. This model does not seem to have the steam vent that other Bosch models...
I've got a 4306, and while it never leaked, the bottom door gasket did seem to chemically melt over the years.
I replaced it a few months ago. I don't know that a steam vent is needed as the gasketing system never allows any steam pressure to build. And, if anything, in general, the gaskets are in worse shape now than when the dishwasher was new, so leakage due to steam pressure would have been greater when new.
Dec 18, 2009 | Bosch Dishwashers
Leakage under glove compartment
Open the hood and on the right side near the firewall you'll see the fresh air intake for the climate control system (heating and ac). Locate the grate which is about the size of a loaf of bread and has fins which run up to the bottom of the windshield. You'll find a foam seal which has deteriorated and will let water into the ac system if it blown in just right. Remove the crappy seal and caulk one side with a thick bead of silicon replace the grate and if you broke the connectors just glue them back with silicon also, use some masking tape to hold it down until the silicon sets. Guaranteed that's where your leak is.
Jan 24, 2009 | 2000 Lincoln Town Car
Leak running down front
Take the recess cup out and seal the area around it right where the front stainless steel panel meets the recess (right at the front of the recess) with clear silicone to prevent water from getting inside the door, then running out of the plastic frame area around the dispenser and running down the freezer door or out the bottom of the door. After the silicone has set, replace drip cup.
Nov 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore HE2 Plus Front Load Washer Logo
154 people viewed this question
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
James Hensley
James Hensley
