Go to the sound icon and right click and press Playback Devices, cick your headphones then properties then advanced and then turn up the sampling rate all the way 24 bit, 192000hz.
Also make sure your batteries are good and windows sound is turned all the way up and lower down on the physical headset.... this took me months to figure out!
Sony Ericsson J108A and Sony Ericsson Cedar is same....You can Unlock it using the Unlock code....You can get Unlock code at reasonable cost at Prounlocking.com/unlock-your-phone/rs8wp2/ and unlock it...Free Unlock code is not possible to get for the Model...
You can stop unauthorized use of your J108a phone by activating phone lock protection.
After activating, you will be asked to enter your phone lock code every time you restart the phone.
The default phone lock code is 0000 (zero-zero-zero-zero). It is recommended that you change this to any four-to-eight-digit personal code.
Note: It is important that you remember your new code. If you forget it, you need to take your phone to your local Sony Ericsson retailer.
To activate the phone lock:
1. Select Menu > Settings > General > PIN codes > Phone protection > Protection. 2. Select 'On' if you want to enter a lock code every time you start the phone, or select 'Automatic' if you want the code to be entered only when the phone restarts after a new SIM card is inserted. 3. Enter the phone lock code (0000 by default) and select OK.
To unlock the phone:
• When 'Phone locked' appears, enter your phone lock code and select OK.
To change the phone lock code:
1. Select Menu > Settings > General > PIN codes > Phone protection > Change code. 2. Enter the old code and select OK. 3. Enter the new code and select OK. 4. Repeat the code and select OK.
This solution was taken from Sony Ericsson J108a user guide which can be downloaded at:
