Question about Samsung YH-820 MP3 Player
Digital audio software - Samsung YH-820 MP3 Player
  • 379 Answers
6ya staff
SOURCE:
You have to turn up the volume to 38+ in order to hear the TV, when you use to be able to hear it at 10, is there a control board that goes out and what Is the name of it?
Hi Geoff, I hope I can help you with this. If you are using an accessory device (DVD, DVR) check cables to see that they are secure and if device has audio out option that it is set correctly. Also check to see that Video and Audio cables are connected to matching inputs on your set.
If you are using DVI to HDMI you will need to use a separate digital audio cable. DVI cables do not carry audio signal. After attaching the audio cable if you still do not hear sound you may need to set Digital Audio In. To do so:
  1. Press Menu Button on remote.
  2. Press the cursor ring down to highlight SETUP.
  3. Press the cursor ring left to enter SETUP menu.
  4. Press the cursor ring down to highlight SOURCE.
  5. Press the cursor ring left to enter SOURCE menu.
  6. Press the cursor ring down to highlight DIGITAL AUDIO IN.
  7. Press the cursor ring down to select the source you want to associate Digital Audio with. HDMI 1 or HDMI 2 in this case. You might need a software update also.
    The latest software solves the issues below:
    1. TV (Plasma 42" and 50") will not turn ON/shut off itself and Red LED blinks 4- times. Recover if main switch on/off.
    2. 37" LCD full white screen appear when upgrade software.
    3. Some channels not available after turn ON.
    4. Delta volume changes, not remembered.
    5. Preferred channel changes, not remembered.
    6. Green or yellow static (sometime snowy) on HDMI picture.
    7. Picture and sound loss for 5 to 10 sec (green LED is still ON) and back to normal.
    8. Audio loss in all inputs and can be recovered when main switch ON and OFF.
    9. TV set turn ON by itself/ green LED light up and goes off when set is ON.
    10. Intermittent audio loss in NTSC RF channel.
    11. Crack sound with high input signal.
    12. Include the possibility to download the rating table (RRT5 capability) for digital programs.
    13. No video/ no picture with sound.
    14. Intermittent On-Screen Menu pop up by itself and can be removed by pressing the 'MENU' button.
    15. Channel information display too long.
    16. Improvement on scramble channel.
    How to check the current software version on my TV set?
    1. Press 'MENU' button on remote control to display the on-screen menu.
    2. Select TV MENU and press the cursor right.
    3. Select INSTALLATION and press the cursor right.
    4. Select SOFTWARE UPGRADE and press cursor right.
    5. Select CURRENT SOFTWARE INFO to display the current software version on your TV set.
    6. If the TV software version is lower than the version posted on the website means your TV set needs to be upgraded.
    7. Follow the instruction in the user manual or Firmware Upgrade Readme file on how to upgrade your software.
    Where can I find the latest software for my TV set?
    The Firmware Upgrade Software and Readme File documents can be found on the Philips support website. Refer to the SOFTWARE section.
Feb 04, 2016 | Televison & Video
Can't hear audio while playing or recording from my Numark to Audacity yet I can hear the audio when the transfer to Audacity is complete.
You will have got the audio muted in your windows recording mode. If you right click on your speaker icon it will say recording devices. Click that and you will be able to see all the devices and if they are activated.
Jun 08, 2017 | Numark ttUSB Turntable
I OWN A AKAI 4000DS MK2 REEL TO REEL TAPE RECORDER, IS IT POSSIBLE TO CONVERT MY TAPES TO DIGITAL. WHAT WILL I NEED? THANK YOU
All you need is to connect the Tape deck via a lead to the audio input of your computer. You can then get a audio recording software (I use and recomend Dan Das Digital Audio Editor). It will record the audio and then you can save it to any number of audio formats. There are some basic processing functions on most Audio Editors, but for more advance features get Audio Cleaning Lab, by Magix. You can record direct with this software. But it's easier to import files into it, due to the fact that they have made the cutting functions complex to use, but the special features easy!
Dec 19, 2009 | Audio Players & Recorders
Unsure of audio setting using Onkyo TX-SR606 connected to PS3
The PS3 should default to the DOLBY DIGITAL sound output so your ONKYO should be setup to the Digital input, TV logic is a matrix similated multi-channel and I doubt if any PS software is in the DTS audio format, look at your game software disc`s and they will inform you of the audio capabilities.
Feb 20, 2009 | Onkyo TX-SR606 Receiver
Digital music audio player H104E/H106E
Here's how you fix it for rca H106:
If you need to update drivers and firmware use the auto updater from http://www.voxxsupport.com/images/downloads/autoupdater.exe
Nov 11, 2008 | Thomson H106 MP3 Player
Digital audio player
it said there is a problem please connect to pc and i need the software to fix the problem
Aug 04, 2008 | Digital Audio Audio Players & Recorders
Need software for innovage digital audio player mp3 wma
Here's the software for this unit, enjoy!
http://rapidshare.com/files/162701522/Innovage.digital.audio.player.software.zip
May 05, 2008 | Audio Players & Recorders
Lost INSTALLATION CD for SAMSUNG DIGITAL AUDIO PLAYER YH-820MW
i have lost INSTALLATION CD for SAMSUNG DIGITAL AUDIO PLAYER YH-820MW. can you please send me a link to download the software for my pc.
Mar 14, 2008 | Samsung YH-820 MP3 Player
Samsung YH-820 MP3 Player Logo
76 people viewed this question
Top Samsung Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
