Question about Nikon Coolpix S3300
No picture on screen - Nikon Coolpix S3300
  • 379 Answers
"It is more likely that it is the image sensor that has failed. It may be sorted out for you under warranty. Take it to an approved Nikon service agent and ask them to have a look at it for you. Get a price to fix it, and then go back to the area Service Manager for the manufacturer. Nikon are a top optics company, am I would attempt to persuade them to fix it for you as warranty, or you will start a HUGE FUSS :) It often works for large companies that have SOME respect for their customers. Give it a try, you will never know unless you have a go. "
Posted on Aug 18, 2013
Anonymous
SOURCE:
When I look to the viewfinder I have a blank screen
Viewfinder, screen and pictures are blank / black - Nikon ...
https://www.ifixit.com/.../Viewfinder,+screen+and+pictures+are+bla...
iFixitMay 4, 2015 - When I look through the viewfinder or at the lcd it is blank / black. Also when I take a picture and view it on my computer, the picture is blank ...
SONY ' eSupport - There is no picture or a black screen ...
https://us.en.kb.sony.com/.../there-is-no-picture-or-a-black-screen-appear...
Dec 8, 2015 - There is no picture or a black screen appears in the viewfinder or LCDwhen attempting to ... Look to see if an image can be seen in the viewfinder or LCD. IMPORTANT: Some camcorders have both a viewfinder and LCD.
There is no picture or a black screen appears in the ...
Jan 11, 2016 | Cameras
LG 55ln5700 picture does not fill screen
Go to picture/video settings and make sure your screen size is set for 16:9 or wide screen ratio.............
If you have dish or cable go into menu settings and check and make sure the same is true
Sometimes on the remote there is a picture size/mode button you can press to change the screen size
Normal or Wide would be widescreen
Stretch is zoomed picture that fills the screen
Letterbox is the square box screen
It sounds like a picture setting problem to me
I would try those things first
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Jul 09, 2013 | Televison & Video
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
How can i save a picture as my screen saver
Assuming you are using windows XP on this:
Create a new folder in "my pictures " folder
Copy the images you want to use into there
On your desktop, RIGHT click and choose "properties" to open the display settings
Click "Screen saver" and choose my pictures slideshow
Click "settings" to open the options for this
Click browse to point to where you saved the images
Set the duration and timings to suit your tastes
Exit by clicking Ok and the OK to exit the display settings
Apr 11, 2011 | Acer Aspire One PC Notebook
HOW TO DO PICTURE MESSAGE
Composing Picture Messages
1. On the All messages screen, tap Compose message. The Compose screen opens. 2. Enter the wireless phone number or email address of your message recipient in the To: box. As you enter the phone number or email address, matching contacts will appear on the screen. Tap a recipient or continue entering the recipient's phone number or email address. Tap the "Tap to compose" text box and then start composing your message. 4. Press Menu and tap Attach. 5. On the Attach window, select Picture.This opens Album to let you attach a picture to your message. 6. When you are finished composing the picture message, tap Send.
To open and view a picture message:
1. On the All messages screen, tap a picture message to open it. 2. Tap the Play button at the right side of a picture message to view it
To reply to a picture message:
1. On the All messages screen, tap a picture message to open it. 2. Tap the text box at the bottom of the screen, compose your picture message (see "Composing Picture Messages"), and tap Send.
Feb 22, 2011 | HTC Hero Smartphone
Picture not filling up the screen
The Vizio HDTV sets are all software driven. With the remote control select the menu option.
Then under the picture tab. look for the picture format full screen, wide screen. select the wide screen option. This setting should fill the screen.
Hope this helps
Bruce
Mar 27, 2009 | Vizio P42HD Television
I would like sto dump my system, and start over. Syst: Gateway GT5220. running Windows XP service pack 3
this will perform an install that will eraseeverything and start over.
  1. Remove all CDs or DVDs from the optical drives.
  2. Turn off the computer using the normal Windows shut down process.
  3. After the computer is turned off, disconnect all USB devices except the keyboard and mouse. This includes USB devices such as a printer, scanner, removable storage, or camera.
  4. Turn on the computer. To start recovery, at the prompt press the F11 key.
    View Picture Note: If this is the first time the computer has been started to the recovery partition, insert the System Restore CD when prompted and then click OK.
    View Picture Files copy.
    View Picture
  5. In the System Restore Options dialog box, select Full System Restore (Destructive), and then click Next.
    View Picture
  6. In the System Restore - Format and Recover dialog box, click Yes.
    View Picture
  7. Files copy.
    View Picture
  8. In the System Restore dialog box, click Restart.
    View Picture
  9. The computer restarts.
  10. Drivers and applications are installed.
    View Picture Note: The following Out of Box Experience (OOBE) screens may vary slightly between models.
  11. In the Welcome to Microsoft Windows screen, click Next.
    View Picture
  12. In the Are your speakers working? screen, click Yes! I can hear the music!, and then click Next.
    View Picture
  13. In the What time zone are you in? screen, select the appropriate time zone, and then click Next.
    View Picture
  14. In the End User License Agreement screen, click Yes I accept for both EULAs, and then click Next.
    View Picture
  15. In the Help protect your PC screen, click Help protect my PC by turning on Automatic Updates now, and then click Next.
    View Picture
  16. In the What's your computer's name screen, type a name for the computer and a description, if desired, and then click Next.
    View Picture
  17. In the What's your Administrator password? screen, type the appropriate information, and then click Next.
    View Picture
  18. In the Is this computer in a domain? screen, click Skip.
  19. The computer checks the Internet connectivity. Please wait.
    View Picture
  20. In the How will this computer connect to the Internet? screen, select the appropriate option, and then click Next.
    View Picture
  21. In the Do you use a username and password to connect to the Internet? screen, select the appropriate option, and then click Next.
    View Picture
  22. In the Setting up a high speed connection screen, select the appropriate options, and then click Next.
    View Picture
  23. In the Ready to register with Microsoft screen, to register with Microsoft after the OOBE screens are completed, select No, not at this time, and then click Next.
    View Picture
  24. In the Thank you screen, click Finish.
    View Picture
  25. Installation is complete. Any application that shipped on a separate CD can now be installed. It is recommended to update the antivirus definitions and perform Windows Updates.
Oct 06, 2008 | Gateway Computers & Internet
KODAK eASYSHARE c530 BLACK SCREEN DOES NOT TAKE PICTURE
You may still be able to take pictures with your black screened Kodak camera. This problem occurs in the line of Kodak EasyShare digital camera models.
When you turn on your Kodak EasyShare digital camera, turn off the LiveView function. Take a picture using the small-windowed viewfinder (this is not the LCD screen). Also, try zooming in and out.
After taking a picture, review the picture to see if the picture has been taken. Then turn on LiveView and occasionally the LCD screen should no longer be showing a black screen.
Aug 31, 2008 | Kodak EasyShare C315 Digital Camera
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Nikon Coolpix S3300 Logo
218 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
